DFi Lan PartynF4 series (FAN PIN HELP) - Overclock.net
post #1 of 14 Old 04-05-2008, 07:32 AM - Thread Starter
333mhz
iCORONA21's Avatar
Quoted: 0 Post(s)
Liked: 1
Send a message via AIM to iCORONA21
As you can see i have a DFi Lan PartynF4 series mother board i bought a heat sink from zalman ( ZALMAN CNPS 9700 NT) and this heat sink has 4 pins to connect to the mother board but my motherboard only has 3 pins for the fan. Is there any way i can convert the 4 pin into a 3 pin or 3 pin into a 4 pin?
Sorry if iam in the wrong thread. Little new to this site.
iCORONA21 is offline
post #2 of 14 Old 04-05-2008, 07:47 AM
Going Broke Overclocking
Quoted: 0 Post(s)
Liked: 1182
I know a 3 pin works on a 4 pin MB, never tied the other way around though.
The 4th pin is common on Intel MBs, I'd think utilizing the correct 3 pins it should work on an AMD MB properly.
Its listed for AMD 939.
"This Zalman cooler is cross compatible between [COLOR=#00FF00 ! important][COLOR=#00FF00 ! important]Intel's[/COLOR][/COLOR] LGA 775 and AMD's sockets AM2 and K8."
http://www.overclockercafe.com/Revie...700NT/pg3.html
Please DO NOT Cite the TOS, simply REPORT and DO NOT REPLY or quote it.
"Life is Learning, Learning is Sharing, Sharing is Life"
"Overclocking is like a drug addiction, the difference is we go broke improving our brain cells instead of destroying them!"
Where in the world to buy on-line
Dual or Multi Partition and Why
Everyone, GET Folding, it is important no matter how much you contribute smile.gif
Phenom II should be called Ph II, not a P II because it isn't an old Intel teaching.gif
The Duke is offline
post #3 of 14 Old 04-05-2008, 07:49 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 75
Send a message via MSN to HauntSheep Send a message via Skype™ to HauntSheep
Hey, i have a 4 pin fan plugged into a 3 pin fan atm
Have the Black, Red, and Yellow wire plugged in - the blue one is only for speed control IIRC
I have it setup like above, and it works fine for me =)
Hope that helps
Photo came out really well
See how ive plugged it in? the blue wire is connected to nothing
HauntSheep is offline
post #4 of 14 Old 04-05-2008, 07:58 AM - Thread Starter
333mhz
iCORONA21's Avatar
Quoted: 0 Post(s)
Liked: 1
let me try it out- I tried it but the only thing it does is just turns on the led.
post #5 of 14 Old 04-05-2008, 08:10 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 75
You do have a 4 pin
This is your motherboard right?
Look by the top PCI slot, that looks like a 4 pin to me
[Appologies if this isnt your motherboard]
Found another NF4 - look by the top PCI again
post #6 of 14 Old 04-05-2008, 08:17 AM - Thread Starter
333mhz
iCORONA21's Avatar
Quoted: 0 Post(s)
Liked: 1
the first picture is how my mobo looks like the second isnt let me check again. (This is probably the 1000 times i checked.)
If you have aim jump on so we can talk faster
aim-lilbrandao4
post #7 of 14 Old 04-05-2008, 09:07 AM - Thread Starter
333mhz
iCORONA21's Avatar
Quoted: 0 Post(s)
Liked: 1
any more thoughts.....
post #8 of 14 Old 04-05-2008, 09:16 AM
Case Modder
soundx98's Avatar
Quoted: 0 Post(s)
Liked: 133
Don't Plug it in to the 4-pin above the PCI-e.
That's for power input from a floppy drive lead off the PSU.
Just make sure the blue wire is NOT connected to anything on the CPU Fan header as previous poster said.
soundx98 is offline
post #9 of 14 Old 04-05-2008, 09:22 AM - Thread Starter
333mhz
iCORONA21's Avatar
Quoted: 0 Post(s)
Liked: 1
K thanks for the info
post #10 of 14 Old 04-05-2008, 09:26 AM
939 Fanboi
nategr8ns's Avatar
Quoted: 0 Post(s)
Liked: 253
My new opteron cooler also has four pins. The blue wire is the only color that I didn't immediately recognize, because black wires are ground, red are 12v, and yellow is 5.5 or something like that (correct me if I'm wrong)
so just don't plug in the blue wire and you should be fine.
And you know how the fan connector will only fit in one way? I.e. not upside down? The 4 pin has the same tab in the way (at least on my cooler) so its really hard to mess it up.
hope this helps.
nategr8ns is offline
