DFI Lanparty UT NF4 Ultra-D overclocking help !!! - Page 3 - Overclock.net
post #21 of 28 Old 12-17-2005, 07:06 PM
ლ(ಠ益ಠლ)
decimator's Avatar
Quoted: 0 Post(s)
Liked: 269
Originally Posted by enzo15
Ok, look on the sticker of your RAM. Does it have part number GE1GB3200BHDC (or GE5123200BHDC)? As long as tehre is the BH in the number, you've got some prime overclocking memory .
enzo15 likes this.
Migration_Sherpa
decimator is offline
post #22 of 28 Old 12-18-2005, 06:43 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 37
and will it work in the dfi board
ill look in a tik kk thanx
enzo15 is offline
post #23 of 28 Old 12-18-2005, 07:07 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 37
the pics are below and it say the following below wich i typed in case you cant read the nice pics that i took
512MB PC 3200
DDR400 CL=2.5-6-3-3
GEL1GB3200BHDC
MADE IN TAIWAN
so does it work with the dfi board that i want will it post if i put this memory in the pc ?
enzo15 is offline
post #24 of 28 Old 12-18-2005, 10:25 AM
ლ(ಠ益ಠლ)
decimator's Avatar
Quoted: 0 Post(s)
Liked: 269
Awesome . Those are Winbond UTT BH-5 chips. They are some of the best chips for LanParty boards. You'll be able to do 250 MHz (DDR500) 2-2-2-5 @ 3.5 volts at first, but after you burn them in, you may only 3.4 or so. Some of these can get up to 270 MHz (DDR540) 2-2-2-5 @ 3.6 volts, but you'll need some good cooling for that amount of voltage. You could probably even use CL1.5, but I don't see the point.
Migration_Sherpa
post #25 of 28 Old 12-18-2005, 03:07 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 37
i read in some reviews that the memory cant do 2-2-2-5 at any voltages i dont want to try it incase i damage it or can i damage it what type of cooling can you get for memory ?
enzo15 is offline
post #26 of 28 Old 12-18-2005, 03:18 PM
333mhz
afnola's Avatar
Quoted: 0 Post(s)
Liked: 5
Heatspreader and good airflow is your options for cooling your RAM. Put a fan on the side of your case that will flow over the RAM if your that worried about it. And, no it isnt true that you cant get 2-2-2-5 at any voltages. Timings will not ruin your RAM, only the heat that is generated by running higher voltages.
afnola is offline
post #27 of 28 Old 12-18-2005, 03:47 PM
333mhz
Quoted: 0 Post(s)
Liked: 0
Not pushing my own gear, but the Zalman CNPS7700 is a great RAM/CPU cooler
If at first it doesn't fit...get the RotoZip
Psychobiker is offline
post #28 of 28 Old 12-19-2005, 03:01 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 37
well iwound this on the actual geil web site
http://www.geil.com.tw/portal/review041204.php
enzo15 is offline
