DFI LP UT NF4 Ultra-D MAJOR problems - Overclock.net
post #1 of 34 Old 05-01-2006, 08:42 PM - Thread Starter
733mhz
brahmabull754's Avatar
Quoted: 0 Post(s)
Liked: 0
I just got this from newegg today, I was able to get it as far as one status light ealier but now the RAM light will never come on anymore. I have been trying all different slots and difference sticks. All 4 power connectors are plugged in. CPU is in securely as is heatsink. The only other thing plugged in is the video card so if it does ever decide to work it can get past the GPU detection part and I can see if it'll boot.
brahmabull754 is offline
post #2 of 34 Old 05-01-2006, 08:52 PM
4.0ghz
Compfreak's Avatar
Quoted: 0 Post(s)
Liked: 71
did u commect all the other power plugs in there is 2 4pin molex and a floppy connector too
92% of teens have moved on to rap. If you are part of the 8% who still listen to real music, copy and paste this.
Second Rig:
Althon64 3000+ @2.7Ghz
MSI K8N NEO4 Platinum S939
OCZ Platinum 2X512 @ DDR600 3,3,3,5 1T
WD 200Gig Sata-II 16MB L2Catch
MSI 2X6600GT GDDR3 @ 625|1250 in SLI
SafePower 550W 24A with Dual 80MM
XP-90+120mm 104CFM+ 2X120mm+2X92mm
Compfreak is offline
post #3 of 34 Old 05-01-2006, 08:55 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 0
All power plugs are connected.
post #4 of 34 Old 05-01-2006, 08:56 PM
4.0ghz
Compfreak's Avatar
Quoted: 0 Post(s)
Liked: 71
have u tried cleaning the cmos?
Second Rig:
post #5 of 34 Old 05-01-2006, 08:58 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 0
Yes several times. I have read that someone had to leave his CMOS in the clear position for like over an hour to get it to clear but that seems ridiculous. Plus I have the CMOS battery out so it should be resetting every time I turn off the power supply (which is about every 6 seconds).
post #6 of 34 Old 05-01-2006, 09:00 PM
4.0ghz
Compfreak's Avatar
Quoted: 0 Post(s)
Liked: 71
do u have an extra videocard? it might be ur card
Second Rig:
post #7 of 34 Old 05-01-2006, 09:05 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 0
It does the same thing with or without a video card in it =/
And no I don't have another PCIE x16 card just an AGP
post #8 of 34 Old 05-01-2006, 09:40 PM
R.I.P Syrillian
Quoted: 0 Post(s)
Liked: 267
This maybe a long shot but try applying a bit of pressure on the chipset block. My expert stoped lighing up the leds if there was not enough pressure on the chipset. Like I said its a long shot, but if the light comes on then it's time to RMA as it will only get worse.
coolsmiley03.png Proud member of the Official All-Canadian Club!!!coolsmiley03.png
MY MOD LOGS
TT Armor Logs - Project Work Log: My Armor Reborn - Project Work Log: The Throne for my Armor
TT Mozart Logs - Project Work Log: Pete's Monstrous Mozart - Progect Work Log: Pete's Monstrous Mozart Overhaul
1 Million+ Folding at Home points
pjlietz is offline
post #9 of 34 Old 05-01-2006, 09:57 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 153
If you have access to an alternate PSU you might want to give that a whirl. Your PSU is the backbone of your system and if you are having issues like you are it should be one of the first pieces of hardware you look at.
You are a special, unique individual... just like everybody else.
euphoricmix is offline
post #10 of 34 Old 05-01-2006, 10:18 PM
Angry Linux Gamer
Melcar's Avatar
Quoted: 0 Post(s)
Liked: 632
Melcar is offline
