fan help - Overclock.net
post #1 of 8 Old 01-13-2011, 01:22 PM - Thread Starter
333mhz
matteg2000's Avatar
Quoted: 0 Post(s)
Liked: 1
just bought a SCYTHE SLIP STREAM 120MM FAN 1900RPM. it has a 3 pin conector that i put in the motherboard, but it will go full speed all the time, wich is loud! any help, the motherboard is a ASUS M4N68T.
matteg2000 is offline
post #2 of 8 Old 01-13-2011, 01:25 PM
Quoted: 0 Post(s)
Liked: 147
get a fan controller to change the settings with it.. and I think you are able to change the fan speed in the bios.
xD3aDPooLx is offline
post #3 of 8 Old 01-13-2011, 02:05 PM - Thread Starter
333mhz
matteg2000's Avatar
Quoted: 0 Post(s)
Liked: 1
was thinking of that but dont want to spend more money, but maybe. i havent find it in the bios :/
post #4 of 8 Old 01-13-2011, 02:08 PM
Quoted: 0 Post(s)
Liked: 147
i seen one on here for 20 bucks. shipped
post #5 of 8 Old 01-13-2011, 02:08 PM
You break it, I fix it.
noobdown's Avatar
Quoted: 0 Post(s)
Liked: 833
noobdown is offline
post #6 of 8 Old 01-13-2011, 03:33 PM - Thread Starter
333mhz
matteg2000's Avatar
Quoted: 0 Post(s)
Liked: 1
it needs to fit in this chassi, whit the chassi door. and its need to be in sweden too xD i tryed speedfan but i show the cpu fan is running at 143rpm and the chassi fan at 7800rpm and i didnt understand it at all xD dont think my mobo is suported so a controler is my option. just have to look harder smile.gif
post #7 of 8 Old 01-13-2011, 03:39 PM - Thread Starter
333mhz
matteg2000's Avatar
Quoted: 0 Post(s)
Liked: 1
no pic? anyway, does ony one know any good pci controler?
post #8 of 8 Old 01-13-2011, 05:25 PM
PC Gamer
croSSeduP's Avatar
Quoted: 0 Post(s)
Liked: 37
Originally Posted by noobdown View Post
Speedfan only works if the fan speed is actually controllable in the motherboard BIOS. I've tried Speedfan, but I kind of ask "why?" If I can't control a fan with it that is not controllable in BIOS, why bother? If it is controllable in BIOS I'll just go that route? Speedfan is one of those free programs that I kind of don't get...
C E N S O R E D
croSSeduP is offline
