Does better cooling = higher OC? - Page 2 - Overclock.net
post #11 of 28 Old 04-18-2008, 02:00 PM - Thread Starter
4.0ghz
Spitphire's Avatar
Quoted: 0 Post(s)
Liked: 14
Originally Posted by roningai View Post
very true about l2n but at this point u think he's actually ready to go that route?
LN2?
I overclock like Flava Flav in a watch factory!
Crysis Benchmark DX10 High 1680x1050 - 35.575FPS
Crysis Benchmark DX10 Very High 1680x1050 - 20.08 FPS
3DMark06 - 14089
3DMark Vantage - H4721
nVidia ForceWare 180.48
Spitphire is offline
post #12 of 28 Old 04-18-2008, 02:01 PM - Thread Starter
4.0ghz
Spitphire's Avatar
Quoted: 0 Post(s)
Liked: 14
Originally Posted by ldk View Post
its basic chemistry. the hotter something is the more it vibrates at the mlecular level and thus the more unstable. the lower the temp the lower the vibration and the more stable, especially in cases of a crysal lattice like a cpu chip.
Is there a program out there to test GPU stability by torturing it? Something similar to Prime95, Orthos, etc?
3DMark06 - 14089
post #13 of 28 Old 04-18-2008, 02:02 PM
Gunga Lagunga
dralb's Avatar
Quoted: 0 Post(s)
Liked: 681
ATI tool artifact test and graphic benchmarks (Crysis, etc.)
dralb is offline
post #14 of 28 Old 04-18-2008, 02:20 PM
Im a worthless nobody
GigaByte's Avatar
Quoted: 0 Post(s)
Liked: 357
For sure better cooling helps overclock, before I flashed my X1900XT to an XTX Toxic the max stable overclock I could get was 648Mhz @ 89c load, I slapped on the AC Accelero X2 at max fan speed and I can now get 675Mhz @ 76c load with a .0025v increase. While I was using the stock cooler add volts did absolutely nothing but add heat.
GigaByte is offline
post #15 of 28 Old 04-18-2008, 02:31 PM
Blameless's Avatar
Quoted: 1 Post(s)
Liked: 3130
If heat is the primary limiting factor, then lowering temps will improve your OC. If it's not, lowering temps probably won't do much of anything (barring an extreme drop).
Most 2900s on stock cooling are temperature limited to a decent degree.
That seems more like physics.
Anyway, the vibrations of atoms/molecules and whatnot are not the direct cause of instability.
LN2?
Liquid nitrogen.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is online now
post #16 of 28 Old 04-18-2008, 02:34 PM
4.0ghz
jph1589's Avatar
Quoted: 0 Post(s)
Liked: 224
If I can lower the temp of my GPU will I be able to get a higher OC? Is it the tempatures that limit speed or the GPU itself?
With all due respect to those who have already answered, nobody can really tell you an answer without first knowing what your temps are at your highest stable overclock.
If you overclock your card to its highest stable point and your gpu temps are still within the thermal specs for that gpu (while under a load), then temperature is not holding back your card at all.
So before answering your question with anything more than a wild ass guess, these all knowing people should have asked what your gpu temps were.
If you are overclocking, read this please.... http://www.overclock.net/intel-memor...rclocking.html
jph1589 is offline
post #17 of 28 Old 04-18-2008, 02:46 PM - Thread Starter
4.0ghz
Spitphire's Avatar
Quoted: 0 Post(s)
Liked: 14
Which is why I asked if there was a program out there to test my GPU at full load so I can see what temp my card is at. I know there is the artifact tool in Ati Tool but I seriously doubt the little graphis running during the test is really stressing my GPU to its limit. And running game benchmarks like Crysis run at full screen so I can't get an acurate temp reading.
3DMark06 - 14089
post #18 of 28 Old 04-18-2008, 02:46 PM - Thread Starter
4.0ghz
Spitphire's Avatar
Quoted: 0 Post(s)
Liked: 14
Liquid nitrogen.
Liquid Nitrogen??? LOL, not going for any records here.
3DMark06 - 14089
post #19 of 28 Old 04-18-2008, 02:47 PM
Gunga Lagunga
dralb's Avatar
Quoted: 0 Post(s)
Liked: 681
Well, explain to me why my 8800gts can reach a higher stable overclock at <60C than I can at a higher temp. The thermal limit of the GPU is much higher than that, but the lower tremps yields more stability.
dralb is offline
post #20 of 28 Old 04-18-2008, 02:49 PM - Thread Starter
4.0ghz
Spitphire's Avatar
Quoted: 0 Post(s)
Liked: 14
But I do think that my question can be answered. It was a very general question.
3DMark06 - 14089
