Looking at replacing the thermal paste for my XFX 5770 (rev2) CrossfireX - Page 2 - Overclock.net
post #11 of 25 Old 06-11-2010, 02:49 PM
3.5ghz
Quoted: 0 Post(s)
Liked: 71
You Have plenty of intake..but how much exhaust do you have?
Chimp Challenge Participant
MeatloafOverdose is offline
post #12 of 25 Old 06-11-2010, 02:53 PM - Thread Starter
333mhz
Sonic_Hedgehog's Avatar
Quoted: 0 Post(s)
Liked: 0
1x 230mm, 2x 120mm exhaust
Sonic_Hedgehog is offline
post #13 of 25 Old 06-11-2010, 02:58 PM
3.0ghz
Rixon's Avatar
Quoted: 0 Post(s)
Liked: 35
So are you using the side 230mm to exhaust? as much as that will remove the air from the sides of the heat-sink since there is no shroud, but remember that you are also taking intake air away, forcing them to intake from elsewhere that might be possibly warm.
Necessity is the mother of all innovation, powered by perfectionism and funded by time.
Rixon is offline
post #14 of 25 Old 06-11-2010, 03:00 PM
Overclocker
Redwoodz's Avatar
Quoted: 0 Post(s)
Liked: 571
Only thing I can think of that would cause this(besides overclocking) is crap T.I.M. installation or heatsink mounting,or slow fan speed.Make sure fan's are @100%,replace the T.I.M..If that doesn't work take 1 card out and check temps.If still hot RMA time.
eek.gifAMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
X6 running 4.125GHz 24/7 @1.47v
Chimp Challenge 2 x Participant
Redwoodz is offline
post #15 of 25 Old 06-11-2010, 03:00 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
Nononono, the side 230mm is used to bring air in, and there is a top mounted 230mm to push air out.
post #16 of 25 Old 06-11-2010, 03:04 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
Well these temps are with the fans @ 100%...
post #17 of 25 Old 06-11-2010, 03:11 PM
KaRLiToS's Avatar
Quoted: 0 Post(s)
Liked: 991
EDIT:
I'm clueless than...sorry
Mod Of The Month September 2012
KaRLiToS is offline
post #18 of 25 Old 06-11-2010, 03:14 PM
4.0ghz
AMD2600's Avatar
Quoted: 0 Post(s)
Liked: 68
If you have a side panel fan use it as exhaust. I recommend putting the new TIM on also.
AMD2600 is offline
post #19 of 25 Old 06-11-2010, 03:46 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
Well I made the side fan exhaust, and the temps were higher. Now the top card does 97 C on Furmark after 4 mins @ stock. So yeah, this is just not working out for me today.
post #20 of 25 Old 06-13-2010, 09:57 AM
Returning Customer
nolonger's Avatar
Quoted: 0 Post(s)
Liked: 266
Change the TIM and tell us how it goes.
My Subzero Runs Thread
^^ Updated 11/04/10
Overclock.net - 2010 Foldathon Participant  Chimp Challenge 2 x Participant  1 Million+ Folding at Home points
nolonger is offline
