New Iceberg 4 Question. - Overclock.net
post #1 of 5 Old 03-15-2006, 06:57 PM - Thread Starter
3.0ghz
TwiztidPOPS's Avatar
Quoted: 0 Post(s)
Liked: 9
I just installed a Iceberg 4 w/ AS5 for my 9800 Pro. Does ithave a break in period like the CPU? If so should I run stock setings before I try overclocking the video card? If so, How long before I start overclocking? Will my overclocks get better with time as the AS5 cures? Right now my clocks are only 395/378.
TwiztidPOPS is offline
post #2 of 5 Old 03-15-2006, 07:20 PM - Thread Starter
3.0ghz
Quoted: 0 Post(s)
Liked: 9
bumpage
post #3 of 5 Old 03-15-2006, 11:27 PM
Angry Linux Gamer
Melcar's Avatar
Quoted: 0 Post(s)
Liked: 632
Just go right to OCing the card keeping an eye on your temperatures. You want to keep load temps. below 65*C (70*C MAX). The AS5 takes some time to break in, so you can expect slightly lower temps. after a while.
Melcar is offline
post #4 of 5 Old 03-16-2006, 04:25 AM - Thread Starter
3.0ghz
Quoted: 0 Post(s)
Liked: 9
I have no temp sensor on my card.....I do however have a homemade cooler that sits on the back of the card w/ a plexiglass shell that vents out the back. Also a 92mm fan tha sits on the botom side panel directly under the video card.
post #5 of 5 Old 03-16-2006, 06:05 AM
4.0ghz
xie67's Avatar
Quoted: 0 Post(s)
Liked: 311
I would suggest a moderate overclock and set the ATITOOL to do an artifact search and leave it run for quite a few hours then let it sit for 1hr or so and fire it up again and bring the overclock back up to near 75% and let it run like that for a couple of days (AS5 optimal performance can be seen around the 200hr mark) but I only give it about 3days on 24/7 with the CPU or GPU under load.
cheers
smil3dbd4e4c2e742.gif...and be happy not mad !
Major changes in the 'Dungeon of Doom' on now
3700+Sandiego KACAE @ 2.85GHz(285x10) 203MHz 2-3-2-5 1Tpost-flame-small.gif3700+Sandiego CCBWE @ 2.42GHz(220x11) 220MHz 2-3-3-6post-flame-small.gif3000+Barton @ inactive for now
xie67 is offline
