6800 Series Aftermarket Cooling Thread - Page 8 - Overclock.net
post #71 of 290 Old 02-15-2011, 02:16 PM
AMD Overclocker
Quoted: 0 Post(s)
Liked: 5
is it true Thermalright Shaman will fit properly without problem with reference 6850 ?!?
reisya is offline
post #72 of 290 Old 02-22-2011, 07:06 AM
1.7ghz
smoke420's Avatar
Quoted: 0 Post(s)
Liked: 23
Add the Ultra U12-40659 Carbon X4 to the list I just got two of them and they fit with no modding .temps are down a lot and they make no noise but the best part is the price.$35 each and get this its the same as the XIGMATEK Bifost with a different sticker and price .lol links below
Ultra U12-40659 Carbon X4 =$34.96
http://www.compusa.com/applications/...361&CatId=4027
XIGMATEK Bifost =$44.99
http://www.newegg.com/Product/Produc...tem=35-233-058
EDIT: the carbon also has a 4 pin connector to power the fan from the video card but the xiggy uses a 3 pin case fan connector
The Official MSI 790FX-GD70 Owners Thread
sneaky.gif: : The Official Corsair H50/H70 Hydro Series Club : : sneaky.gif
smoke420 is offline
post #73 of 290 Old 03-06-2011, 08:03 PM
PC Gamer
illusive snpr's Avatar
Quoted: 0 Post(s)
Liked: 12
Does anybody know if you can buy a twin frozr 2/3 kit to put on a 6870? I have been looking but am having no luck finding the kit(if it exists).
illusive snpr is offline
post #74 of 290 Old 03-07-2011, 09:02 AM
333mhz
Calexan's Avatar
Quoted: 0 Post(s)
Liked: 5
ok this got me interested since i was planning on buying a bitfrost & was hoping
to find something about it here.. & viola here it is hehe..
can you show me some screenies with your temps? a definite +rep if you do hehe..
Calexan is offline
post #75 of 290 Old 03-07-2011, 09:21 AM - Thread Starter
2.4ghz
Tommie's Avatar
Quoted: 0 Post(s)
Liked: 36
Thx guys for adding the info, I just updated the thread. It's been a while.
It does become a bit complicated now that custom boards are out. If you have a Trad you should check if you have the same kind of board as Mentalcrisis00 ( page 7 )
Losers sit at home drooling over their computers
Winners date the prom queen.
Tommie is offline
post #76 of 290 Old 03-10-2011, 09:11 AM
1.7ghz
smoke420's Avatar
Quoted: 0 Post(s)
Liked: 23
Top card max temp:78c 970/1120 1.25v
Bottom card max temp: 81c 970/1120 1.18v
not that good at posting pics and this one is big.first some info the cards are 6850's not 6870's so this is a pretty huge overclock and furmark is maxed out msaa x8,xtreme burning mode ,and post fx on.stock for these cards is 790/1000 this pic is of them both at 970/1120 for 45mins.Ambient temp was 26c.
before the coolers these clocks were only possible for suicide benchmark runs with way too much voltage and I saw 99c in one run of heaven 2.1..Now I can game all day at these settings and most games move the cards off idle very little.games that aren't to damanding like bulletstorm maxxed out stays 51c.My fan is set to hit 100% just above 70c but the cards never get that hot and the fans are silent at any rpm.
not the best coolers on the market but you cant get anything half as good for the price.DONT get the bifrost a xigmatek sticker is not worth $10
Calexan likes this.
smoke420 is offline
post #77 of 290 Old 03-10-2011, 09:48 AM
333mhz
Calexan's Avatar
Quoted: 0 Post(s)
Liked: 5
though there is scythe mushashi & Gelid icy vision but it's too expensive for me :/
thanks for info btw think im gettin a bitfrost will post temps here..
Calexan is offline
post #78 of 290 Old 04-12-2011, 06:10 PM
Overclocker
CLeeFESQ's Avatar
Quoted: 0 Post(s)
Liked: 16
I think I need some help. I just installed a Twin Turbo Pro, and the fans are spinning but I have no fan control. Everything is plugged in (if it weren't they wouldn't be spinning). Has this happened to anyone before?
CLeeFESQ is offline
post #79 of 290 Old 04-12-2011, 08:34 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 35
Use a program like Afterburner to do fan control for TTP. RPM readings will get funky (least for me) and say I'm in the millions for RPM if I change it to anything except 100%. I keep it at 100% anyway. But you should barely notice the fan's audible noise change when you do fan control via a program like afterburner.
".. used to be a cop, now I got wanted posters on every I-HOP" -William "Ricky Ross" Roberts
I edit my posts at times, so feel free to refresh the page a minute or 2 later to see what I may have added/removed/edited.
GSkill Ripjaws Fitting with a Silver Arrow!
- credit goes to those who took the pictures, I put this up as reference to people considering a D14/SA but question ram compatibility.
yoshi245 is offline
post #80 of 290 Old 04-12-2011, 08:42 PM
Overclocker
CLeeFESQ's Avatar
Quoted: 0 Post(s)
Liked: 16
Yes they were very funky just as you described. So I am getting fan control, I'm just not noticing it? If so, then I'm not very impressed by this cooler. Noise is down a lot, but temperatures are about the same. The thermal paste is not cured yet I'm sure, so that could have something to do with it.
CLeeFESQ is offline
