[Build Log] Deep Thought - Case Labs MH10 Water Cooled EVGA SR-2 Build - Page 5 - Overclock.net
post #41 of 76 Old 07-20-2012, 08:22 PM - Thread Starter
Overclocker
Quoted: 0 Post(s)
Liked: 7
Originally Posted by Citra View Post
I think he thinks your running osx on it?
Anyways the build looks great, especially the case.
Sent from my HTC EVO 3D X515a using Tapatalk 2
Nah, no way. That would violate the EULA. Wink wink, nudge nudge.
2 Million+ Folding at Home points
braindeadmac is offline
post #42 of 76 Old 07-20-2012, 08:33 PM - Thread Starter
Overclocker
Quoted: 0 Post(s)
Liked: 7
Duh. Measure twice, cut once. Or measure twice, buy once. First wrinkle. I was going to have radiator connections in the back but the case, but it won't quite work as neatly as envisioned. Radiator to radiator connection interferes with mounting the 68 mm case top. Yes, I could mod the top, but I sort of hate to drill holes in this case labs stuff...just too nicely thought out. Well, this opens all sorts cans of worms up, like even putting the radiators in parallel rather than serial....I'm going to sleep on it.
post #43 of 76 Old 07-20-2012, 11:09 PM
Quoted: 0 Post(s)
Liked: 127
Use the G1/4" connections that face down instead of off the back?
Electrocutor is offline
post #44 of 76 Old 07-21-2012, 12:13 AM
*cough* Stock *cough*
barkinos98's Avatar
Quoted: 0 Post(s)
Liked: 71
superhead91: We have reached a point where we're seriously discussing whether we need 6 cores or 20 cores to be able to browse the web more efficiently. What a time to be alive.
Other Builds (Click to show)
Chimp Challenge Participant  Foldathon Folder - 2013 Participant
barkinos98 is offline
post #45 of 76 Old 07-21-2012, 06:31 AM - Thread Starter
Overclocker
Quoted: 0 Post(s)
Liked: 7
Blah. Couldn't sleep. Visions of water loops danced in my head....So I settled on this orientation for radiators. LOL, then got inpatient and rough-installed aquaero stuff. Wish I had taken pictures of all the variations I tried along the way. Nap time. Then more coffee and plumbing today.
post #46 of 76 Old 07-21-2012, 02:24 PM - Thread Starter
Overclocker
Quoted: 0 Post(s)
Liked: 7
Well, I originally planned on both of the pumps going into the bottom area, but I had clearance issues up top with the hard drive cage. So I wound up putting the reservoir in horizontally. If I had two MCP35x2 pumps or even mcp35x instead of the Aquastream, I could have had both pump systems in the bottom. Alternatively, I could have left the radiator in the bottom of the case rather than side mounting it, but I like the aesthetics of this better. LOL for one thing the radiator hides the rats nest of cabling caused by me using extensions. There are two separate pump loops, each loop draws from the bottom on the side opposite where it enters.
post #47 of 76 Old 07-21-2012, 02:26 PM - Thread Starter
Overclocker
Quoted: 0 Post(s)
Liked: 7
Here's the Aquastream and my drain port hole drilled; the fill port was backordered. Fits in pretty easily, lots of room around stuff.
post #48 of 76 Old 07-21-2012, 09:58 PM - Thread Starter
Overclocker
Quoted: 0 Post(s)
Liked: 7
post #49 of 76 Old 07-22-2012, 09:24 AM - Thread Starter
Overclocker
Quoted: 0 Post(s)
Liked: 7
OK, 6 hours of leak testing...so far so good.... I have a short in a fan wire....grrr. Of course just noticed I left the hard drives plugged in. Oh well, no power to MB and GPU...that's where the real money sits anyway....
post #50 of 76 Old 08-13-2012, 05:29 AM - Thread Starter
Overclocker
Quoted: 0 Post(s)
Liked: 7
