[Budget Build] System 1 Celestia - Overclock.net
post #1 of 4 Old 07-24-2012, 10:52 AM - Thread Starter
Audiophile
ITAngel's Avatar
Quoted: 0 Post(s)
Liked: 23
System 1 Name: {¨¨°º©o.,,.o©º°¨¨" Celestia "¨¨°º©o.,,.o©º°¨¨}
CPU: AMD A8-3850 Llano 2.9GHz Socket FM1 100W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 6550D
CPU Cooler: Stock
MOBO: GIGABYTE GA-A75M-D2H FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD
RAM: Team Xtreem Dark Series 8GB (2 x 4GB)DDR3 1600
Video Card: APU AMD Radeon HD 6550D
POWER: Enermax Noise Taker II 485watt
DVD-Drive:
CASE:
MONITORS:
(1): 19" ACER LCD
(2): 19" ACER LCD
Total Cost: $ 195.99 (Cost of new parts CPU+Mobo+Ram)
*The Build
-Pictures-
Clean out the old system motherboard and ready to install the new stuff to this one.
As you can see these motherboards fit nice on mid side PC case.
Pluging some cables around but wish I had these wire organized much better.
Almost done with the install, so far no problems what so ever.
All the cable plug in and system is up and running no issues so far.
As you can see here because I only own one SATA DVDRW here from my other PC. I needed to pull it and run it here to install Windows 7 64bit Pro.
More Pictures to come...
**The Test
Windows Is installed, so far most stuff install and working fine. Not going to go to much into detail on this system since it will not be OC right now because my wife uses this system. However I will try to put in some time to do some benchmark testing and so on for you guys later on.
***The Configuration (OC)
****The Test 2
***** The Retire Systems & Parts (Memorial)
The old parts have been donated to a good friend of ours and can still run the minimum setup for Guild Wars 2.
ITAngel is offline
post #2 of 4 Old 07-25-2012, 08:39 AM
PC Gamer
truckerguy's Avatar
Quoted: 0 Post(s)
Liked: 209
are you going to have pic's?
truckerguy is offline
post #3 of 4 Old 07-25-2012, 08:59 AM - Thread Starter
Audiophile
ITAngel's Avatar
Quoted: 0 Post(s)
Liked: 23
Yup i will starting the project this friday evening. If all the packagest get here in time. I clean yesterday my work area. I am so excited biggrin.gif.
ITAngel is offline
post #4 of 4 Old 07-25-2012, 09:20 AM
PC Gamer
truckerguy's Avatar
Quoted: 0 Post(s)
Liked: 209
good deal
