The Monolith: Antec P180b build - Page 8 - Overclock.net
post #71 of 96 Old 12-29-2006, 05:20 PM
The Odd Mod
Quoted: 0 Post(s)
Liked: 1172
Originally Posted by leimrod View Post
these drives have always ran hot for some reason. Even now they are idling at 45'c. I have the 12cm fan in the middle of the bottom chamber, i'll probably add another 12cm fan to the front to increase airflow. I think my OCZ PSU is generating alot of heat down there though.
Are those the KS's? Those drives are known to run hot. My quad pack also runs at a nice 50C when I give them a full workout. Nothing to worry about; it seems they can handle it easily. Great drives, but a bit hot, which is another reason to keep them in the bottom chamber.
Chozart is offline
post #72 of 96 Old 12-29-2006, 05:29 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 66
I've got the one tricool in the middle of the bottom chamber on high now and its dropped my HDD temps to 43'c idle, i'd say with another fan infront of them I can get them down to mid 30's. Putting the tricool on high hasn't really changed my perceiveble system noise at all.
Sig designs | Build Log: Antec P180b | Lapping Guide: Tuniq, Opty 165, HR-05 | OC LOG: Opty 165, Mushkin RAM, 7900GTX
HTPC: HAL 1.0
CPU: E6600 @ stock
RAM: 2x1GB Mushkin HP6400
Mobo: Gigabyte GA-965QM DS2
GFX: eVGA 8800GTX
HDD: WD 500GB SATA w/ Vista 32bit
Case: Lian li PC-V300
leimrod is offline
post #73 of 96 Old 12-29-2006, 05:48 PM
The Odd Mod
Quoted: 0 Post(s)
Liked: 1172
Chozart is offline
post #74 of 96 Old 12-30-2006, 01:58 PM
Commodore 64
Bamboo's Avatar
Quoted: 0 Post(s)
Liked: 0
Hey, looked into the antec p150, and can't handle the white. So looked at the antec SOLO, and am wondering if anyone has tried to fit a 8800GTX in one of either of these. If not, I may just stick with the P180, cause it still looks the best.
Bamboo is offline
post #75 of 96 Old 12-30-2006, 02:18 PM
They've Killed Fritz!!!
Mr Pink57's Avatar
Quoted: 0 Post(s)
Liked: 263
Send a message via MSN to Mr Pink57
Leimrod.
Have you had any luck with a fan in front of the drives at the bottom? I wanna put a fan there but am curious what will fit. My two Maxtors are getting pretty hot down there however the PSU is very cool and maybe revs up to 1000rpm.
pink
Vicki Vale: You're insane!
Joker: I thought I was a Pisces!
Mr Pink57 is offline
post #76 of 96 Old 12-30-2006, 04:29 PM
AMD Overclocker
DontPassTheFence's Avatar
Quoted: 0 Post(s)
Liked: 76
Send a message via AIM to DontPassTheFence
^^ Ive got that same problem, trying to fit a fan in front of the drives at the bottom there, for temp Ive got a 120mm AC silent out infront, but now the case door doesnt close fully - LOL!
I have 2 KS drives (both 2500KS) down there and temps start to jump up with the fan in the middle, so I took out the middle fan and it cools the upper HDDs now.
Id be interested in seeing how anyone can better fit a fan in front of the drives in the bottom chamber there (dremel req`d) and what fits (I hope a silverstone will fit as I just ordered 2 of them...)
DontPassTheFence is offline
post #77 of 96 Old 12-30-2006, 10:49 PM
The Odd Mod
Quoted: 0 Post(s)
Liked: 1172
I ziptied a 92mm fan on the inside of the bottom chamber. It just fits such that the hdd bracket can still slide in it's place. It does help me cool the quad pack (now down to two hdd's, since rig two 'borrowed' the other pair)
Chozart is offline
post #78 of 96 Old 12-31-2006, 06:47 PM
Mr Pink57's Avatar
Quoted: 0 Post(s)
Liked: 263
I dont really wanna go that route due to some of my wiring already goes thru there and helps me keep it clean. If I can just get one up front I will be happy.
pink
post #79 of 96 Old 12-31-2006, 06:48 PM
Audiophile/Car lover
pbasil1's Avatar
Quoted: 0 Post(s)
Liked: 460
Send a message via Yahoo to pbasil1
sooo jealous!
Like cars? Carforum!
How to choose the right fan
what is " folding " ???
When you take an old graphics card and effectively 'fold' it in half, in order to remove the chip.This process takes alot of power.
pbasil1 is offline
post #80 of 96 Old 12-31-2006, 07:30 PM
Mr Pink57's Avatar
Quoted: 0 Post(s)
Liked: 263
http://www.newegg.com/Product/Produc...MP=OTC-Froogle
http://www.newegg.com/Product/Produc...82E16835185026
I think I found the solution! This fan will fit up front as a 92mm fan fits just fine also I checked a minute ago. The reason I dont use the 92mm is its a Silverstone. Also I think most of us can control this fan with your mobo's thru speedfan I know all the DFI mobo's do.
pink
