[Build Log] The Define Project - Page 6 - Overclock.net
post #51 of 347 Old 10-21-2012, 05:36 AM
WaterCooler
mandrix's Avatar
Quoted: 0 Post(s)
Liked: 170
Yeah I've put a lot of time into sleeving too. Making up all my wiring and sleeving it as I go. I still have the two PCI-e connectors left to fab up and sleeve. I'm not very quick at sleeving, just slow and steady.
Maximus VIII Hero/6700K delidded w/CLP @ 4.8/Corsair LPX 4x4GB 2666 OC'd @ 3200/PCS 390X w/EK blockMain Rig specs (Click to show)
White Case Labs SM8 w/dual pedestals-Custom top extension
Rigid acrylic tubing/Dual D5's-MCP35x2
3x480mm-1x240mm Radiators
All psu wiring & sleeving by myself
2xAquaero 5 Pro's w/c - 1xFC8 for light panel & various led's
PowerColor PCS 390X w/EK block
6700K/Maximus VIII Hero/Corsair 4x4GB RAM
Build Logs (Click to show)Validations (Click to show)
mandrix is offline
post #52 of 347 Old 10-23-2012, 10:33 AM - Thread Starter
News Fiend
adi518's Avatar
Quoted: 0 Post(s)
Liked: 37
Came up with a new plan for the LC setup, I have no idea if it's going to work but I already saw someone fixing the res like this:
Btw, I pretty much decided to go with XSPC's Raystorm block for the cpu, I think it's pretty slick and performance should be great. I'm also on the hunt for EK's old 680 block design. Those two combined and I think I'm golden!
BOARD G1.Sniper 5 CPU i7 4790k GPU 2x GTX 970 SC RAM 16GB G.skill Sniper HDD 480gb OCZ Vertex 460 + 128gb Crucial M4 PSU Seasonic P-760 DISPLAY U2410 OS Win 10 Pro WHEEL CSW V2 RIM BMW GT2 PEDALS CSP V3
adi518 is offline
post #53 of 347 Old 10-24-2012, 10:27 PM
K4IKEN's Avatar
Quoted: 0 Post(s)
Liked: 16
K4IKEN is offline
post #55 of 347 Old 10-25-2012, 05:35 AM
*cough* Stock *cough*
Adriel's Avatar
Quoted: 0 Post(s)
Liked: 0
Subbed! Excited for all the work you're putting into this as well as us future R4 WC owners smile.gif Keep it coming! biggrin.gif
Adriel is offline
post #56 of 347 Old 10-25-2012, 01:31 PM
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Subbed
post-flame-small.gifPhanteks Owners Club post-flame-small.gifpost-flame-small.gifWays to Better Cooling post-flame-small.gif
post-flame-small.gif1. Controling PWM Case Fans post-flame-small.gif2. Optimizing Case Cooling post-flame-small.gif3. Cooler Size Comparison & Cooling Comparison
=i7 980 @ 3.55GHz =PH-TC14PE w/2x TY-143 fans =Crucial Ballistix 3x4GB =GA-X58A-UD5 =ASUS GTX580 DirectCU II =Enermax Modu84+ =Define R2 w/3x TY-140 case intake fans; all PWM controlled by CPU fan socket
Phanteks Enthoo Primo MoBo Rampage III Extreme CPU i7 980xCooler R1 Ultimate w/ TY-147A fans RAM Dominator GT 6x2GB GPU ENGTX580 DCUII PSU Corsair TX850 Case [/COLOR]Phanteks Enthoo PrimoBase custom caster base
=i7 980X @ 4.0GHz =R1 Ultimate w/2x TY-143 fans =Dominator GT 6x2GB =Rampage III Extreme =ASUS GTX580 DirectCU II =TX850 =Enthoo Primo w/ custom castor base
doyll is online now
post #57 of 347 Old 10-25-2012, 09:17 PM - Thread Starter
News Fiend
adi518's Avatar
Quoted: 0 Post(s)
Liked: 37
SSD Mounts:
Basically, the case comes ready with two stealth mounts for SSD but (and it's a big one) you have to install the SSD BEFORE you install the motherboard. That means it's a PITA to take it off when needed. So, I picked up a nice piece of 90-degree angled aluminum and made mounting brackets that will separate the attachment of the SSD from the case:
After second layer of matte black paint:
To perfect the mounts I decided to prep it for conical screws (up right you can see it more clearly).
Next pic will be with the mounting brackets installed in the case. smile.gif
adi518 is offline
post #58 of 347 Old 10-26-2012, 10:32 AM - Thread Starter
News Fiend
adi518's Avatar
Quoted: 0 Post(s)
Liked: 37
Fit test:
Also added these:
adi518 is offline
post #59 of 347 Old 10-26-2012, 10:33 AM
K4IKEN's Avatar
Quoted: 0 Post(s)
Liked: 16
K4IKEN is offline
post #60 of 347 Old 10-26-2012, 11:13 AM - Thread Starter
News Fiend
adi518's Avatar
Quoted: 0 Post(s)
Liked: 37
Replaced picture (really hard to make good pictures with the iphone 4). I bought them from Moddiy. I was sure Nils from MDPC sells them but apparently not. smile.gif
adi518 is offline
