ITX build for my wifey - Page 2 - Overclock.net
post #11 of 14 Old 09-16-2012, 07:12 PM
kelvintheiah's Avatar
Quoted: 0 Post(s)
Liked: 13
its my opinion anyway. just plug a 7000 series gpu and it should be a beast.
kelvintheiah is offline
post #12 of 14 Old 09-17-2012, 02:49 AM - Thread Starter
Fan Man
JanqeD's Avatar
Quoted: 0 Post(s)
Liked: 11
Lol why? She doesnt play any games that require a graphics card. The 4000 will handle what she needs a respectable frame rates for a general user
JanqeD is offline
post #13 of 14 Old 09-17-2012, 02:51 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 240
i'd get cheaper case an only 4 gb ran and put the saved money in to a used low-medium ranged gfx card.
the reason being is she DOES paly games that require a gfx card mainly sims 3 and wow the built in intel gpu won't cut it. i'd get like a hd6670 which would be more than plenty though it wouldn't be able to do max settings in wow.
There are some decent cases to be had for 50 bucks the nzxt gamma and nzxt m59 are both 50 bucks or cheaper shipped on either newegg or amazon.
EDIT:EDIT, the only way the hd400 is playing those games is at the lowest possible resolution and with the lowest settings. It can JUSTbarely handle left 4 dead which is less demanding than WoW.
cdoublejj is offline
post #14 of 14 Old 09-17-2012, 03:42 AM - Thread Starter
Fan Man
JanqeD's Avatar
Quoted: 0 Post(s)
Liked: 11
Ive used the 4000 on wow and it has handled fine. The case was chosen for specific reason of placement on our desk. She rarely plays games and the ig can handle it at quality she is okay with. If she ever becomes an avid gamer I will be not have a problem buying some cheap gpu but for now the 4000 has proven capable of playing these games at levels she is okay with. (I have the same processor and we've tested it) Thank everyone for your concerns about just the gpu lmao
//CLOSE PLEASE smile.gif//
JanqeD is offline
