[Build Log] Beginner's Luck - X79 Build - Page 3 - Overclock.net
post #21 of 286 Old 10-31-2012, 02:16 PM
WaterCooler
Father Fuzzy's Avatar
Quoted: 0 Post(s)
Liked: 14
Love your Case
yes Caselabs have raised the bar for all other manufacturers
and thats a good thing
Father Fuzzy is offline
post #22 of 286 Old 10-31-2012, 04:53 PM - Thread Starter
First Time Build
ballnuts's Avatar
Quoted: 0 Post(s)
Liked: 4
Originally Posted by Loonies View Post
Originally Posted by Father Fuzzy View Post
Love your Case
Nice Catch! Fixed that. Thanks for stopping in.
ballnuts is offline
post #23 of 286 Old 10-31-2012, 04:55 PM - Thread Starter
First Time Build
ballnuts's Avatar
Quoted: 0 Post(s)
Liked: 4
Update!:
  • Performance PC order came in today. Everything was well packed. Great customer service from these guys.
  • My tubing cutter, bitspower fittings (black sparkle), Power adjust 2's, and some other goodies.
ballnuts is offline
post #24 of 286 Old 10-31-2012, 05:05 PM
Programmer
Leyaena's Avatar
Quoted: 0 Post(s)
Liked: 62
shinies!
Leyaena is offline
post #25 of 286 Old 10-31-2012, 06:34 PM
WaterCooler
Quoted: 0 Post(s)
Liked: 14
Nice regiment of fitings
good pics
i'm in for the long haul
post #26 of 286 Old 11-01-2012, 12:25 PM - Thread Starter
First Time Build
ballnuts's Avatar
Quoted: 0 Post(s)
Liked: 4
Originally Posted by Leyaena View Post
shinies!
good pics
Hello and welcome to the party. grouphug.gif I'm excited to see how the fittings end up looking with the rest of the build...
UPDATE!:
  • Frozencpu order came in
  • Decided to return the EK blocks and go with something different...updates soon...
  • Ran into some issues last night, hopefully everything is ok, pics with descriptions to follow
You can see in this pic that I forgot to install the motherboard I/O shield... I had no idea what was in store for me....
You can see in this pic (below) the padding on the I/O shield. This makes it EXTREMELY difficult to mount the motherboard. You basically have to set the mobo on the standoffs, and push and hold the motherboard in place while fighting about 10 - 15 lbs of lateral force (pushing the i/o components into the i/o shield padding.)
Also, I can image the bottom of the board was rubbing on the standoffs while trying to do this...
I tried everything from taking the back panel off the motherboard tray, which was a terrible idea because those screws aren't really meant to come out. I stripped and had to replace 2 screws. Also, it matters not when you remove the back cover because it attaches to the tray via hinges, and they are impossibbru to put back together with the motherboard installed. So at this point, I actually had to uninstall the mobo again and re-assemble the motherboard tray before re-installing.
Hopefully everything is OK with the motherboard, but I don't see any other way to overcome this aside from maybe purchasing a custom IO shield.
You can also see here if you blow up the picture that the I/O shield bows out a little bit on the back. IMO I really hate Asus, I think they're much more bent on the bottom line than they are quality. Makes me a little sad putting this board in this case, but there really isn't a better option from what I could tell.
I googled it, but it looks like I'm the only one who really had an issue with this. I just can't imagine any other way of doing it though...Was definitely very difficult to install.
ballnuts is offline
post #27 of 286 Old 11-01-2012, 12:52 PM
TheBadBull's Avatar
Quoted: 0 Post(s)
Liked: 34
Subscribed. :)
Edit: Aw, man... stupid asus. :/
1 Million+ Folding at Home points
TheBadBull is offline
post #28 of 286 Old 11-01-2012, 02:12 PM
Aluminum Enthusiast Cases
Jim-CL's Avatar
Quoted: 0 Post(s)
Liked: 250
It's rare, but some MB manufacturers get a little sloppy with their heat shields. The problem is compounded by the thickness of the newer ones as well has the tight tolerance fit to the on-board connectors. I ran into something similar with an ASUS Maximus IV Extreme board last week. The "trick" is to rock the MB into place aligning it with the heat shield and then laying it down on the stand-offs. A bit of a pain, but if we try to "fix" it, we'll just end it breaking it for everyone else. Our cases are built to the ATX spec (version 2.2). Hopefully ASUS (and others) will eventually get their act together.
www.CaseLabs.net * Email: CS@CaseLabs.net * Follow us on Facebook
*** Made in the U.S.A. ***
Jim-CL is offline
post #29 of 286 Old 11-01-2012, 03:34 PM - Thread Starter
First Time Build
ballnuts's Avatar
Quoted: 0 Post(s)
Liked: 4
I just wish there was someone, anyone, who made a better motherboard. I would ditch asus in a heartbeat. Welcome to the fun BadBull!
Yea Jim, I did sort of the same thing. I just didn't like that the standoffs were moving around a little bit on the bottom of the mobo while doing the final push to compress the padding on the heat shield. And yea, it's their design that causes the problem. I found 2 other things with the Asus board that really made me feel that I was dealing with a low quality product: Hard to reach the gpu lock latches with card installed, and the way they setup that OC key wire with a little rubber fitting is just ridiculous. I tried for 10 minutes to get that thing in there, and couldn't. Wasted probably 3 hours last night dealing with those issues. wha-smiley.png
Despite the Asus issue, I keep finding little nuances with the caselabs that I really like,. smile.gif
ballnuts is offline
post #30 of 286 Old 11-01-2012, 04:54 PM - Thread Starter
First Time Build
ballnuts's Avatar
Quoted: 0 Post(s)
Liked: 4
UPDATE:
Frozen CPU order came in...
Here are some other pics from last night... The samsung SSD's look perfect in this case to me.
ballnuts is offline
