[Build Log] Project Blue Rain(Prodigy) - Page 4 - Overclock.net
post #31 of 307 Old 01-14-2013, 07:06 AM - Thread Starter
PC Gamer
audioholic's Avatar
Quoted: 0 Post(s)
Liked: 41
Plus I already have blue black and white paracord so I can begin sleeving, next in the list is order the razor gpu block..some mayhems pastel white and go from there. biggrin.gif
I am waiting to see more results from running a single 240 rad. Hmm maybe some Aurora fluid to show off for a couple months smile.gif
audioholic is offline
post #32 of 307 Old 01-14-2013, 07:13 AM
PC Gamer
SonofJor-El's Avatar
Quoted: 0 Post(s)
Liked: 43
Let me ask you--what size paracord are you using? And I hope you are doing before and after pics so we can see the results biggrin.gif
SonofJor-El is offline
post #33 of 307 Old 01-14-2013, 07:19 AM - Thread Starter
PC Gamer
audioholic's Avatar
Quoted: 0 Post(s)
Liked: 41
Just 50/50 . I have a surplus store right in my town...and since I was military he gives me a good price biggrin.gif
There will before and after. I am going to make custom wires though. probably make small extensions so I can get 1 to 1 pinout and get that rainbow arch.
I love sleeving but after doing 3 power supplies I am all about extensions now lol.
Now I just need to decide on my radiator size and get this build going!
post #34 of 307 Old 01-14-2013, 07:55 AM
PC Gamer
Quoted: 0 Post(s)
Liked: 43
I understand that as this will be my first time sleeving. I even ordered white connectors thumb.gif I ordered from MODDIY. If I need more sleeving or if I ordered the wrong sizes, perhaps you could assist me? I am pretty excited about it biggrin.gif I thought about extensions but there is too much wire and very little space. I want a clean look. I wish I could help with rads but I never done water cooling before so I am unable to assist there frown.gif
*Stands and salutes* Thank you for serving thumbsupsmiley.png:
post #35 of 307 Old 01-14-2013, 08:01 AM - Thread Starter
PC Gamer
audioholic's Avatar
Quoted: 0 Post(s)
Liked: 41
Yea man if youre doing paracord I could definitely help you out!
Paracord is easy to work with although sleeving with say MDPC sleeving is easier for heatshrink less. What kind of sleeving did you order? Do you have a link?
post #36 of 307 Old 01-14-2013, 08:15 AM
PC Gamer
Quoted: 0 Post(s)
Liked: 43
I ordered heatshrink as well:
http://www.moddiy.com/products/Deluxe-High-Density-Weave-White-Cable-Sleeve-%283mm%29.html
I figured this was some good stuff but we will soon see as I am waiting. I ordered 3mm and 4mm.
post #37 of 307 Old 01-14-2013, 08:53 AM - Thread Starter
PC Gamer
audioholic's Avatar
Quoted: 0 Post(s)
Liked: 41
So guys after long hours of thinking I have finally decided to go with 2 240mm rads in this build. I'm going to order either Alphacool or XSPC slim rads.
post #38 of 307 Old 01-14-2013, 08:56 AM
PC Gamer
Quoted: 0 Post(s)
Liked: 43
XPSC FTW!! I know I have not done watercooling, their rep seems better wink.gif
post #39 of 307 Old 01-14-2013, 09:10 AM - Thread Starter
PC Gamer
audioholic's Avatar
Quoted: 0 Post(s)
Liked: 41
Alphacool rads are great, but I think I will go with the XSPC rads. Since I am using all the blocks from them anyway biggrin.gif
post #40 of 307 Old 01-14-2013, 09:22 AM
PC Gamer
Quoted: 0 Post(s)
Liked: 43
