$800 Build - Overclock.net
post #1 of 15 Old 12-17-2008, 01:06 PM - Thread Starter
4.0ghz
PeaceMaker's Avatar
Quoted: 0 Post(s)
Liked: 122
Hey guys,
Putting this compute for a friend, he wants as good as or better of a computer to mine on this budget.
Let me know what you think:
http://secure.newegg.com/WishList/Pu...Number=9235171
Will also need KB+Mouse+wires but I assume this isn't' included in the budget.
Thanks guys.
"Signature your on it put, backwards this read to enough dumb were you if."
Disclaimer: Everything I say is my own opinion unless I provide evidence.
PeaceMaker is offline
post #2 of 15 Old 12-17-2008, 01:11 PM
Case Modder
NoodleGTS's Avatar
Quoted: 0 Post(s)
Liked: 175
Hey,
I would go for an E5200 instead of that E8400 and use the extra money for a GTX260 or 4870. With some overclocking this will def. give you better gaming performance.
NoodleGTS is offline
post #3 of 15 Old 12-17-2008, 01:15 PM - Thread Starter
4.0ghz
PeaceMaker's Avatar
Quoted: 0 Post(s)
Liked: 122
Theres a big difference between the E5200 and the E8xxx. E5200 is the same type of processor as the E2xxxx
post #4 of 15 Old 12-17-2008, 01:29 PM
4.0ghz
heathmcabee's Avatar
Quoted: 0 Post(s)
Liked: 126
I like the build. Though you probably could get a cheaper power supply for that system (not manufactereur just price) and get yourself a 4870 or GTX260, which would be much nicer.
PeaceMaker likes this.
90% of statistics are made up, and 50% of them aren't true.
heathmcabee is offline
post #5 of 15 Old 12-17-2008, 01:37 PM - Thread Starter
4.0ghz
PeaceMaker's Avatar
Quoted: 0 Post(s)
Liked: 122
That PSU is pretty good after the rebate. Is the GTX 260 or 4870 that much better?
post #6 of 15 Old 12-17-2008, 01:44 PM
1.7ghz
BobbyChicken's Avatar
Quoted: 0 Post(s)
Liked: 43
True, but if it's mostly for games, the processor really isn't that important, so I would go ahead and spend the money on the graphics card.
Also, 700w is definitely overkill, but I guess it allows for an upgrade. On the whole it looks pretty good, though.
BobbyChicken is offline
post #7 of 15 Old 12-17-2008, 01:49 PM
qTAP's Avatar
Quoted: 0 Post(s)
Liked: 87
nooo.... CPU is really important. if you get a $100+ video card it will bottleneck. get an E8400.
qTAP is offline
post #8 of 15 Old 12-17-2008, 01:53 PM
Tweaking Addict
Quoted: 0 Post(s)
Liked: 398
Hey guys,
Thanks guys.
...and monitor
List looks good although I might go with the E8400 for $164 with free shipping.
Also need a CD/DVD drive (combo/burner) and what about operating system?
Don't forget the retention bracket for that Xiggy.
After that - good to go
Slider46 is offline
post #9 of 15 Old 12-17-2008, 02:16 PM - Thread Starter
4.0ghz
PeaceMaker's Avatar
Quoted: 0 Post(s)
Liked: 122
Originally Posted by Slider46 View Post
...and monitor
good points! +reps
I was thinking about upgrading to E8400.
post #10 of 15 Old 12-17-2008, 02:31 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 126
Ya, you will definately appreciate the upgrade in graphics card rather than your power supply.
