need help overclocking my old dell - Overclock.net
post #1 of 5 Old 01-23-2010, 08:46 PM - Thread Starter
Commodore 64
thomas260's Avatar
Quoted: 0 Post(s)
Liked: 0
I'm trying to overclock my dell optiplex 270 and am having no luck. I cannot find a clock generator number to use SETFSB. Along with my bios not having the option to make any changes. Its at 2.2ghz and i know it could be better. Is there anything i can do to help it along? The chipset is a intel 865p/pe if that helps any. Any help would be greatly appreciated.
thomas260 is offline
post #2 of 5 Old 01-23-2010, 08:49 PM
Knows the Song of Time
greydor's Avatar
Quoted: 0 Post(s)
Liked: 414
No. There are a few software overclocking options you can use, but none that I would recommend. You're going to need to build to have the options that you want.
greydor is offline
post #3 of 5 Old 01-23-2010, 09:38 PM - Thread Starter
Commodore 64
thomas260's Avatar
Quoted: 0 Post(s)
Liked: 0
any inexpensive recomendation on what to use?
post #4 of 5 Old 01-23-2010, 09:44 PM
333mhz
COBSAD's Avatar
Quoted: 0 Post(s)
Liked: 6
I'm gonna agree with skitzo here, software overclocks are sketchy, but if youre determined check this one out:
http://www.filecluster.com/System-Ut...-ClockGen.html
COBSAD is offline
post #5 of 5 Old 01-24-2010, 12:31 AM - Thread Starter
Commodore 64
thomas260's Avatar
Quoted: 0 Post(s)
Liked: 0
i've tried clockgen and it wont work for some reason it only brings up the clocks and nothing to make any changes, its kinda crazy. I dont think dell wanted anybody messing with their setup on these.. Any thoughts on a inexpensive mobo and cpu combo that is not expensive and is quick along with being tunable.. I'm kinda new to the overclocking thing... Figured this would be my best start. Thanx guys
