rate $800 build - Page 2 - Overclock.net
post #11 of 17 Old 06-22-2010, 08:51 PM
ლ(ಠ益ಠლ)
decimator's Avatar
Quoted: 0 Post(s)
Liked: 269
Oh, you're swapping out your system part by part? Well, I would recommend you buy the mobo, CPU, and memory together so that you have as little downtime as possible. Then you can upgrade everything else one at a time. I would probably upgrade the mobo, CPU, RAM, and case first. Getting the big stuff out of the way is always nice . This way, you don't have to transfer all of your new hardware to your new case piece by piece.
decimator is offline
post #12 of 17 Old 06-22-2010, 10:12 PM
Velathawen's Avatar
Quoted: 0 Post(s)
Liked: 123
SC2 really isn't that taxing, though it does seem to enjoy quads. My friend is running a E6850 Core 2 Duo with a GTX 260 (both stock) and has close to 60 all the time on ultra at 1900x1200. With MMO, you tend to want a faster spinning hard drive, which the Spinpoint F3 will fit perfectly.
Velathawen is offline
post #13 of 17 Old 06-23-2010, 06:37 PM - Thread Starter
Commodore 64
tbgriffith's Avatar
Quoted: 0 Post(s)
Liked: 0
Thanks for the feedback everyone! I'll let you guys know how everything goes when I go through with it!
tbgriffith is offline
post #14 of 17 Old 06-23-2010, 06:42 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 1203
The one suggestion I would add is to do your best to up the graphics card budget. If you can find a cheaper motherboard, you should be able to get your budget up near $175. At that price point, our For Sale section would offer a lot of GTX2xx series cards and those will outperform the 5770. You won't have DX11, but you can always upgrade the gpu a year or more from now if DX11 offers something you want/need. I don't believe a 5770 will cut the mustard when games really start rewarding DX11.
Comp #2: Intel 2500k, GTX480, MSI P67AGD55, 4gb G Skill, X-Fi XtremeMusic,Logitech Z5500, 24" Gateway LCD, Antec P180,3 striped 36gb Raptors + 1 500gb, Hyper 212+, Corsair 520HX.
Comp #3:Intel 2500k, GTX480, MSI P67AGD55 , 4gb G Skill, Antec 650W, Logitech 560 4.1, 24" Acer LCD, Chenming MidTower, Liteon DVDRW, 74gb Raptor + 500 gb, Hyper 212+, Creative X-Fi XtremeGamer.
Comp #4: Intel 2500k, MSI 6950 2gb, Asus P8P67A, 4gb G. Skill, 22" Acer LCD,Raptor 150, Hyper 212+, Logitech 530, Antec P180, Antec TruePower 650w,Creative X-Fi XtremeMusic,Liteon DVDRW
sccr64472 is offline
post #15 of 17 Old 06-23-2010, 06:50 PM
2.4ghz
Scottery's Avatar
Quoted: 0 Post(s)
Liked: 40
For the post above me the card would have to be higher than a GTX260 core 216 to out perform the HD5770. Don't go out and buy something like the GTX210 and think you have a good card.
OP probably got sucked into a dimensional rift when he opened the computer. Now he is on an epic quest to save the world from evil in order to return home.
Scottery is offline
post #16 of 17 Old 06-24-2010, 04:27 PM
ლ(ಠ益ಠლ)
decimator's Avatar
Quoted: 0 Post(s)
Liked: 269
This combo deal is a great buy for you. You should still be within budget with it, but shipping might push you tad bit over $800. Still, this is a great buy.
post #17 of 17 Old 06-24-2010, 04:30 PM
ZealotKi11er's Avatar
Quoted: 6 Post(s)
Liked: 1787
Send a message via Yahoo to ZealotKi11er
For the GPU try to get HD 5850 or if you find a cheap GTX465.
CPU History (Click to show)
CPU -> Sempron 2400+, Athlon 64 3700+, Core 2 Q6600, A8-3870K, Core 2 Q9550, Core 2 QX9770, Core i7 920, Core i5 2500K, Core i5 3570K, Phenom II X4 955, Core i7 3770K.
GPU History (Click to show)
FX 5200 128MB, 9800 Pro 128MB, 6800GS 256MB, 7600GT 256MB, HD 4850 512MB, HD 4870 1GB, 2x HD 4870 1GB, GTX280 1GB, HD 5850 1GB, GTX470 1.25GB, GTX580 1.5GB, HD 6950 2GB, HD 6950 2GB + HD 6970 2GB, HD 6990 2GB, HD 7970 3GB, 2 x HD 7970 3GB,R9 290 4GB, R9 290X 4GB, R9 Fury X 4GB, GTX 1080 8GB, GTX1080 Ti 11GB
MB History (Click to show)
ECS KN1 Extreme -> ASUS P5Q-E -> GIGABYTE GA-X58A-UD7 -> GIGABYTE GA-Z68XP-UD4 -> GIGABYTE GA-Z77X-UD5H -> ASRock Z77E-ITX
ZealotKi11er is online now
