[CHECK-UP] Sleeving AX860 & other cables - Overclock.net
post #1 of 6 Old 10-16-2013, 07:36 AM - Thread Starter
WaterCooler
xioros's Avatar
Quoted: 0 Post(s)
Liked: 190
Send a message via Skype™ to xioros
Do I have everything?
It's for this build: The Monolith
I will be sleeving the AX completely, the SATA wires, fan cables etc...
Am I missing something?
(I have a heatgun)
Thanks in advance!
-Xioros
xioros is offline
post #2 of 6 Old 10-16-2013, 10:51 AM
.:Cable Sleeving Evangelist:.
Lutro0's Avatar
Quoted: 0 Post(s)
Liked: 539
Send a message via AIM to Lutro0 Send a message via Skype™ to Lutro0
(I have a heatgun)
Thanks in advance!
-Xioros
It all looks to be good, but if I may add a few suggestions...
You will want more sata sleeve and maybe 2 more sata hs - this is if you have not done them before.
A dumping pack is a buttload, also you may want to think color choices as it will blend your system nicely - try looking at red, color-x, gray, black and then pick a combo like red, gray, black (which is what I would do IMO) Or another good one is red, colorx, black.
3 color schemes are the best looking imo and they show that you took your time to make the cables a part of the system instead of hiding all your hard work.
You will want more HS as well I know 6X50 seems like allot but if you want to get them perfect you will burn through them quick.
Also I HIGHLY recommend getting my LC Sleeving Tool - this will speed up your hs style and allow you to easily get straight looking professional cables : https://lutro0-customs.myshopify.com/products/lc-sleeving-tool
Also a good snips is key: https://lutro0-customs.myshopify.com/products/lc-flush-cutter
And finally you will need the round molex extractor to get the 4pins removed: https://lutro0-customs.myshopify.com/products/round-4pin-extractor
And for the rest of the connectors you can use an exacto knife to get them off.
For heatshrink style I recommend a good heatgun : https://lutro0-customs.myshopify.com/products/heatgun
Also lastly - to know exactly how much sleeve and hs to buy check out my FAQ stickied to this subforum.
Also watch these videos: http://www.youtube.com/watch?v=fdckzRWFijM&feature=share&list=PLPZbMurO9Ou3Ya2Qkn1uVIQfbkmY5inda
http://www.youtube.com/watch?v=rFWIt3qSEAk&feature=share&list=PLPZbMurO9Ou3Ya2Qkn1uVIQfbkmY5inda
http://www.youtube.com/watch?v=j7QYiu7pJis&feature=share&list=PLPZbMurO9Ou3Ya2Qkn1uVIQfbkmY5inda
That should about cover it! Let me know if you have any more questions.
xioros likes this.
.-[Owner - MAINFrame Customs]-.
.-Reason I Live-.
[Project Log]:[ Aspros ]: Currently Working
[Project Log]:[ Katharos ]: April MotM Winner
[Project Log]:[ Elektron Mod ]: Currently Working
[Project Log]:[ Xýlo Kai Chalkó ]: Currently Working
Lutro0 is offline
post #3 of 6 Old 10-16-2013, 11:05 AM - Thread Starter
WaterCooler
xioros's Avatar
Quoted: 0 Post(s)
Liked: 190
Thanks for the big response! (rep'd)
Some things:
I already have a heat gun (well, it's on its way tongue.gif )
And I have a "normal" (but very good and sharp) cable cutter, it that sufficient?
About colors:
For my Monolith, I chose for a as-clean-as-possible black "shadow" style (Similar to the Munderbox, but I doubt I can even get close to this masterwork redface.gif )
That's why I chose pitch black. (The original idea was a ROG style red-white-black, but the red will kill the black style)
Thanks a lot for the video's.
-Xioros
xioros is offline
post #4 of 6 Old 10-16-2013, 11:16 AM
Lutro0's Avatar
Quoted: 0 Post(s)
Liked: 539
As long as its nice and sharp it will work, also try maybe black. shade19, and dark gray. Or just black and shade 19. Trust me you will be glad you didnt go all black.
xioros likes this.
.-Reason I Live-.
Lutro0 is offline
post #5 of 6 Old 10-16-2013, 01:08 PM - Thread Starter
WaterCooler
xioros's Avatar
Quoted: 0 Post(s)
Liked: 190
Since you're the God of Sleeving, I think it's safe to trust you on this one redface.gif
Any advice on color ratio (how much black and how much shade19?) and order of colors?
Thanks (rep'd)
xioros is offline
post #6 of 6 Old 10-16-2013, 01:15 PM
Lutro0's Avatar
Quoted: 0 Post(s)
Liked: 539
Thanks (rep'd)
I am not a god of anything, I just like helping people to get into sleeving by getting them the knowledge and the perfect supplies and tools for their jobs. There is so many little details that can make or break a sleeving project.
These are colors from my shop www.lutro0customs.com
https://lutro0-customs.myshopify.com/collections/pet-sleeving
Teleios is easy to work with and its in the states so you can get it faster. I also sell everything else needed.
May I suggest that you try heatshrinkless sleeving is this is your first time?
Check this video out and you will see what I mean.
http://www.youtube.com/watch?v=-rmj5B8z1Os&feature=share&list=PLPZbMurO9Ou3Ya2Qkn1uVIQfbkmY5inda
.-Reason I Live-.
Lutro0 is offline
