Magnum smh10 question - Overclock.net
post #1 of 9 Old 07-23-2013, 02:28 AM - Thread Starter
Sarf's Avatar
Quoted: 0 Post(s)
Liked: 1
Is it required to install the divider for the middle and lower part of the case?
Sarf is offline
post #2 of 9 Old 07-23-2013, 10:37 AM
Aluminum Enthusiast Cases
Jim-CL's Avatar
Quoted: 0 Post(s)
Liked: 250
Yes it is (for structural integrity) and to support the MB tray.
www.CaseLabs.net * Email: CS@CaseLabs.net * Follow us on Facebook
*** Made in the U.S.A. ***
Jim-CL is offline
post #3 of 9 Old 07-23-2013, 08:34 PM - Thread Starter
Sarf's Avatar
Quoted: 0 Post(s)
Liked: 1
Can't it be replaced by the vertical/horizontal bars instead for support or is it still not enough?
Sarf is offline
post #4 of 9 Old 07-24-2013, 08:58 AM
Jim-CL's Avatar
Quoted: 0 Post(s)
Liked: 250
The horizontal supports are designed to be used on the outside edge of the frame. It would be a significant mod to support the tray and remove the mid plate.
Jim-CL is offline
post #5 of 9 Old 08-25-2013, 08:15 PM
neo mouse's Avatar
Quoted: 0 Post(s)
Liked: 0
Another question about the SMH10. is it possible to fit a Monsta 560 and a Monsta 280 in the lower chamber and still have room for fans and a power supply?
neo mouse is offline
post #6 of 9 Old 08-26-2013, 02:19 PM
Jim-CL's Avatar
Quoted: 0 Post(s)
Liked: 250
As long as you have a single bank of fans - yes. Otherwise there isn't enough span between the mounts (217mm) for P/P
Jim-CL is offline
post #7 of 9 Old 08-26-2013, 06:13 PM
neo mouse's Avatar
Quoted: 0 Post(s)
Liked: 0
Fantastic, thats for the info.
post #8 of 9 Old 08-27-2013, 09:18 AM
Jim-CL's Avatar
Quoted: 0 Post(s)
Liked: 250
Jim-CL is offline
post #9 of 9 Old 08-27-2013, 09:21 AM
ATI Enthusiast
ledzepp3's Avatar
Quoted: 0 Post(s)
Liked: 114
1995 Chevy Impala SS: Dark Cherry Metallic, Nitto NT555's (255/40/W17), Flowmaster 40 Series Mufflers, stock 350-LT1 V8. The Daily.
2006 Pontiac GTO: Brazen Orange Metallic, 6-speed, Stock Internal 6.0L LS2 V8, SLP Long Tube Headers, SLP Loudmouth II Cat-Back, Custom Catless Mids by Red's Muffler, Trickflow Intake, BMR Aluminum Skidplate, Hinson Motorsports Single-Piece Aluminum Driveshaft w/ Forged Chromoly Yolks, Hinson Motorsports Short-Throw Shifter, Melling High-Volume LS2 Oil Pump, Powerbond 15% Underdrive Pulley, SCSS Oil Pressure and Boost/Vacuum Gauges, BMR Sub-Frame Connectors, BMR Strut Tower Brace, Hotchkis Front/Rear Sway Bars, Roadsafe Bushingless Front Swaybar Endlinks, Tow Brace Delete, Hinson Polyurethane Transmission and Motor Mounts, Koni Adjustable Shocks and Struts, Whiteline Upper Rear Shock Bushings, Whiteline Differential Support Insert, Whiteline Upper Strut...
100 Million+ Folding at Home points  Foldathon Folder - 2013 Participant
ledzepp3 is offline
