Ordering my first Case Labs case! Parts Check! - Page 2 - Overclock.net
post #11 of 11 Old 12-02-2013, 02:41 PM
DaaQ's Avatar
Quoted: 0 Post(s)
Liked: 125
Originally Posted by thrgk View Post
I am buying the sth10 tho. I do have the 120x4 drop mount in my cart, and 1 bottom mount, but do I need anything else? I will be doing the 2 360s+PSU in the top and 2 360s in the bottom
You need the side mounts to do what you are suggesting
The drop in mount is for the very top, which you could use with an extended top cover, to get a total of 3 rads up top. But let me tell you, that would be extremely top heavy.
If you used the top mount for fans only, you would need the 30mm top cover. If that is something you may want, it is cheaper to get now than to order separately later.
You're just nitpicking words now. I was talking about in terms of performance, those are the only measurements that matter. Not IPC or clock speed.
If Bulldozer came out of the box at 5 ghz and overclocked to 6 ghz on air, no one would have said it was a failure.
DaaQ is offline
