"Project Sil3nT" Building test system. - Page 7 - Overclock.net
post #61 of 1503 Old 11-08-2011, 06:10 AM - Thread Starter
333mhz
sil3nt_dr3ams's Avatar
Quoted: 0 Post(s)
Liked: 60
Decided to stick with the coarsir motherboard tray. Purely because of the thickness and quality of the steel. When you buy cases you get what you pay for.
Cheap sheet metal benders are great but you really have to think how you bend items. Clamps lots of them, pieces of scrap steel. The idea is to have as much surface tension each side of the bend so you bend in a straight line.
MadGoat
“Sometimes it better to just scrap and start... lost ingenuity leads to loss of ambition”.
My Quotes
“You can choose to be a sheep and follow the pack or you can choose to be the Sheppard that leads the flock of sheep".
sil3nt_dr3ams is offline
post #62 of 1503 Old 11-08-2011, 07:28 AM
Ol' Ho-Bag
repo_man's Avatar
Quoted: 0 Post(s)
Liked: 208
The bend looks nice man!
Syrillian: "Watch out World... here I come (rawwwr?)"
The life and continuance of Syrillian's Silentium: Repo and Syrillian's Silentium
The Rest of My Work -- Vapor Locked // Sanguineus Cinis Cineris // Hinges for Syrillian's Silentium // Project: Phoenix // Flip this Tower
Case Mod Comp '09 Intermediate Winner:
Chlokwork Orange
repo_man is offline
post #63 of 1503 Old 11-08-2011, 07:37 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 60
Thanks bro, just the beginning. All you guys should beable to follow this and repeat these steps. The sheet metal bender is 80$ ebay.
Looks factory biggrin.gif.
MadGoat
My Quotes
post #64 of 1503 Old 11-08-2011, 08:50 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 60
Wow feel like Im winning this war reclaiming the case back. Only need to house two drives my server takes care of the storage.
Finally I have some direction in this build, I've been working on a order to frozen cpu for the last 4 days adding subtracting parts, I'm glad I did'nt hit purchase other wise I would only be using a 2x 120mm radiator as my second radiator. Now im leaning towards a quad 120 low profile.
MadGoat
My Quotes
post #65 of 1503 Old 11-08-2011, 09:53 AM
dave1991's Avatar
Quoted: 0 Post(s)
Liked: 3
dave1991 is online now
post #66 of 1503 Old 11-13-2011, 04:40 AM
Case Modder
Katcilla's Avatar
Quoted: 0 Post(s)
Liked: 4
Subbed! This is turning into a quite informative and interesting build.
Katcilla is offline
post #67 of 1503 Old 11-13-2011, 10:43 AM
AMD Overclocker
Furball Zen's Avatar
Quoted: 0 Post(s)
Liked: 87
Tutorials: Modular PSU ~ Remove foam from Sunbeam FC ~ Builds: Blue on Black ~ Worklog: Carbide
Mods/Laser work: DVD-ROM Mod ~ Custom HD4890 and HDD backplates
"YOUTUBE: revealing all the stupid people on earth...one video at a time."
Furball Zen is offline
post #68 of 1503 Old 11-14-2011, 02:53 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 60
Well here's pretty much the idea I'm working on . I'm going to to use 2x tripple rads in a sealed rad box. Build the box and then fit everything around it. I like the idea of a rad box but I dont like the idea of having this externally.
Im waiting on another big order from frozen cpu and finalizing a big order from FTW sleeving.
MadGoat
My Quotes
post #69 of 1503 Old 11-14-2011, 03:22 AM
733mhz
TKNOHCKR's Avatar
Quoted: 0 Post(s)
Liked: 9
TKNOHCKR is offline
post #70 of 1503 Old 11-14-2011, 03:27 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 60
Im using 0.95mm mild steel ignore the gal, I should not be using it. Makes it alot harder to paint. It's all i could get when i finished work. But on the upside you dont have to worry about any surface rust while fabricating. You can use 0.65mm for smaller panels and if your worried about the weight. I'm not worried about weight thinking I'm past that.
On a small sheet metal bender like the 85$ one im using I would not try to bend anything more than 09.mm.
This is how you bend a simple bend, keep your bends over 40mm, reason being is you have more clamping surface which creates less flex. Nicer bend.
When your working out sizes dont forget to allow for the bend itself, I'm losing 3-4 mm for the bend itself.
MadGoat
My Quotes
