Scratch Case Mod: Project Annexed! [wooden PC case :P] - Page 5 - Overclock.net
post #41 of 159 Old 02-12-2012, 03:35 AM - Thread Starter
Case Modder
LokSupguller's Avatar
Quoted: 0 Post(s)
Liked: 39
Ahh, so are you saying I must ground my powersupply some how? So I have to attach the powersupply case to some other metal component so that it touches the ground or table?
Thanks for the information! And yes I will research on that, and how I could ground the components in my case
Thankyou very much! I will need your help probably for the rest of my planning and I hope you will keep a vigil over my mods and plans as I post them up, thank you very much for helping!
Scratch Case-mod: ANNEXED
Featuring 600mm tall plywood panels, entirely rearrange components and WATERCOOLED thumb.gif
Other CASE Mods....
LokSupguller is offline
post #42 of 159 Old 02-12-2012, 05:15 PM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 39
Upcoming update guys!
Other CASE Mods....
post #43 of 159 Old 02-12-2012, 07:35 PM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 39
Update 6
HEY GUYS!
I think I did quite a bit of wood-working last weekend, although it would have taken an easy 10minutes with the proper power-tools, this mod took me half the day to complete with only a cordless drill and an Ozito Rotary Tool with faulty sanding drums.
So, I'm working on the motherboard panel as Silent Dreams has advised me to thumb.gif
The panel clamped down and ready for cutting
So, what I will be working on is:
  • SATA Cable, 24 Pin cable, I/O Cables, other motherboard cables etc. routing holes
  • CPU cooler/heatsink backplate mounting hole access.
  • Watercooling inlets and outlet holes (to and from cooling compartment)
Massive drill bit aye?
Well it's the biggest I have, and it still isn't big enough
I placed too much pressure on one hole and this is the result:
The rotary tool:
I've had horrible experiences with these sanding drums, partly because I left them outside and the constantly changing weather loosened the glue on the abrasive paper, but these keep splitting apart after a minute of usage.
Let's see how they do for this
How I'm going to widen the holes.
But somehow, after burning through over 5 sanding drums I got the job done
These are the wider-diameter sanding drums, they lasted much longer than the narrow ones so I'm glad I had these thumb.gif
Now, time for the routing holes for the motherboard:
The process was very slow, I drilled consecutive holes around the edges of the marked out areas and used a thin blade to saw the center out. Then I proceeded to sanding the jagged edges.
The top 2 are complete
Now for the SATA and 24 pin cable holes...
And the rest...
With that complete, I'm moving onto the Backplate acess hole:
Look at all the dust on my arm, my hairs are even white
Done
RESULTS:
Wiped up and left to dry
Meanwhile, I've got some cleaning duties to attend to D:<<br />
Now wirth everything cleaned up I can putty up some holes caused by splintering:
Urk : s
Never fear, the putty is here!
And that's the completion of the motherboard panel!!!!
Sanding and painting doesn't really count because that's just the final touches (:
So yeah, I'm glad I got the motherboard tray done this weekend so I can move onto other things, such as researching about grounding the case and figuring out the PCI backplate (thanks again to Silent Dreams)
That's it for now, I won't have another update until next weekend but I will post up plans and whatnot.
Stay tuned for more guys!!!
Other CASE Mods....
post #44 of 159 Old 02-13-2012, 12:38 AM
Audiophile
Big-Pete's Avatar
Quoted: 0 Post(s)
Liked: 41
Warning: Spoiler! (Click to show)
Originally Posted by LokSupguller View Post
Update 6
HEY GUYS!
The rotary tool:
And the rest...
Done
RESULTS:
Meanwhile, I've got some cleaning duties to attend to D:<<br /> img1628c.jpg
Urk : s
looks awesome buddy!
WANT FREE STUFF?! CLICK HERE (just list me as referral)
JOIN THE NEW BF3 Platoon HUUAH! Click to Join.
LOLZ! (Click to show)
Donkey1514: All I need in my life is Boys Boys Boys doop dee doop doop doop.
Clock Speed 24/7! (Click to show)Add Me Up! (Click to show)
Steam: petes89
Origin: 23BigPete
Hit Me Up Tell Me Your From OCN.
Chimp Challenge Participant  5 Million+ Folding at Home points  Foldathon Folder - 2013 Participant
Big-Pete is offline
post #45 of 159 Old 02-13-2012, 10:26 AM
born to folk
Niko-Time's Avatar
Quoted: 0 Post(s)
Liked: 298
Yeah, looking really good.
By the power of truth, I, while living, have conquered the universe.
Niko-Time is offline
post #46 of 159 Old 02-13-2012, 05:15 PM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 39
Other CASE Mods....
post #47 of 159 Old 02-14-2012, 05:15 PM
PC Gamer
Cykososhull's Avatar
Quoted: 0 Post(s)
Liked: 18
Nice work so far.
Cykososhull is offline
post #48 of 159 Old 02-15-2012, 03:50 AM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 39
Originally Posted by Cykososhull View Post
Nice work so far.
Thank-you very much Cykososhull! (funny name there biggrin.gif )
I won't be doing anything major this week or the week after, I have to somehow get the money to buy an extra sheet of 7mm plywood biggrin.gif
And I've got school work to do.
But i put something together for tommorow so stay tuned for that!
Other CASE Mods....
post #49 of 159 Old 02-16-2012, 04:23 AM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 39
Upcoming update guys!!
Other CASE Mods....
post #50 of 159 Old 02-16-2012, 04:37 AM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 39
Update 7
HEY GUYS!
Whew, the fifth update of this worklog already.
So I finished cutting up the motherboard panel in the latest update, although it's not 'finished' as in sanding, painting and coating with protective layers.
To test if I did the holes right (please god please....) and to make my next move in this case mod I installed a few motherboard stand-off screws to fit an mATX motherboard (which should have roughly the same motherboard mounting holes except for the ones on the outer edge)
Sorry about the bad image quality!!! It was getting late and I didn't bother turning the incandescent display-light on.
The camera flounders in darker conditions:
Screwed in:
Done!
Better pictures...
Ofcourse, this is only an mATX board so a standard motherboard would reach close to cable routing holes.
The I/O panel of the motherboard:
How the motherboard is elevated from the panel:
The CPU back-plate access hole.
The mounting holes seem to be off currently, this is because the CPU HSF mounting holes of a mATX board are closer to the top, meaning it is shifted slight upwards so it seems I did it wrong in the photo, but after searching and measuring the ATX board of my dad's desktop the distance between the socket and top edge of the board is much larger tongue.gif
Getting closer....
How the female connectors of the I/O panel will be sticking out:
It's just right (thankfully). I doubt the motherboard I will be purchasing will have such types of connectors.
Yay! I got the SATA cables and 24 Pin routing holes aligned right! biggrin.gif
Now it's school time and I've got it all locked down, since plywood bends horribly over time I'm pinning the planks of plywood down with quick-grip clamps and C-clamps until I am working on them next week.
I will be purchasing another sheet of 7mm HOPEFULLY next week, and I can also get the guy at bunnings to cut it down to size for me (only just knew when a friend told me LOL)
Well stay tuned for more guys!
Other CASE Mods....
