[Complete] Project Prodigious - OCN's March 2013 MOTM! - Page 67 - Overclock.net
post #661 of 934 Old 02-03-2013, 09:30 PM - Thread Starter
Case Modder
adamski07's Avatar
Quoted: 0 Post(s)
Liked: 96
Originally Posted by <({D34TH})> View Post
haha.. i know, if that happens I won't put it here and instead put in my 2500k.. lol
Originally Posted by Ezekie1Enus View Post
You Definitely have my vote for MOTM. Probably the only mod I've been following where I've seen real progress, other than a CM Storm Trooper one but it was like 1/10th the scale that this one was.
Wow. Thanks! won't disaapoint you all til the last mod of this build. smile.gif
Originally Posted by Norlig View Post
tongue.gif ask admins... haha
Originally Posted by Roadkill95 View Post
Same.
Originally Posted by dmanstasiu View Post
Originally Posted by KillThePancake View Post
https://www.facebook.com/AdamskiMods
adamski07 is offline
post #662 of 934 Old 02-04-2013, 03:48 AM
Networking Nut
Quoted: 0 Post(s)
Liked: 3
Jaacckk is offline
post #663 of 934 Old 02-04-2013, 08:22 PM - Thread Starter
Case Modder
adamski07's Avatar
Quoted: 0 Post(s)
Liked: 96
Originally Posted by Jaacckk View Post
After testing out bitfenix hydro pro and corsair SP fans, they just didn't like each other. frown.gif At low speed, SP fans makes annoying ticking noise. I know this is very common on fan controllers + fans and I can not stand that noise. At full speed, the quiet edition SP fans are sooooo quiet that I decided not use the fan controller anymore or maybe still use it and run them at full speed at all times since I will be OCing at high clock. Anyway, I got no real update for now. Still working on shortening cables and then sleeve it. Also, the loop should be done tomorrow and ready to be filled up with coolant. Hopefully by the end of the week, I can finish both water cooling and sleeving to get the system up running. thumb.gif
post #664 of 934 Old 02-05-2013, 12:43 AM - Thread Starter
Case Modder
adamski07's Avatar
Quoted: 0 Post(s)
Liked: 96
First 8 pin.. done! Not perfect, but it looks good to me! smile.gif I need more practice sleeving cables.. haha biggrin.gif Anyway, it is my first time doing this. 24-pin and two pci-e cables left. I will continue sleeving tomorrow. smile.gif
post #665 of 934 Old 02-05-2013, 06:02 AM
PC Gamer
audioholic's Avatar
Quoted: 0 Post(s)
Liked: 41
audioholic is offline
post #666 of 934 Old 02-05-2013, 08:08 AM
Case Modder
AlderonnX's Avatar
Quoted: 0 Post(s)
Liked: 53
Looks good to me
AlderonnX is offline
post #667 of 934 Old 02-05-2013, 10:24 AM
dmanstasiu's Avatar
Quoted: 0 Post(s)
Liked: 154
Which sleeving did you use?
Derickwm, EK Employee: "The motherboard will be safer in the blender"
Sunreeper: Yeah dman is so Canadian that he oozes out maple syrup
Chimp Challenge Participant  2 Million+ Folding at Home points
dmanstasiu is offline
post #668 of 934 Old 02-05-2013, 10:54 AM
PC Gamer
audioholic's Avatar
Quoted: 0 Post(s)
Liked: 41
looks like Nils handy work there(MDPC)
post #669 of 934 Old 02-05-2013, 02:15 PM
Intel Overclocker
Ezekie1Enus's Avatar
Quoted: 0 Post(s)
Liked: 4
I really wanna see the 24-pin. Also, that sleeving looks fine. The only time that I feel sleeving needs improvement is when there is uneven heatshrink or, they didn't pull it tight enough on a rainbow-coloured 24-pin. Heatshrinkless is the way to go in my book. I have done some heatshrunk sleeving but the amount of time to get it even and looking good and also the added expense just isn't worth it.
Ezekie1Enus is offline
post #670 of 934 Old 02-05-2013, 04:20 PM
SpeedBump613's Avatar
Quoted: 0 Post(s)
Liked: 7
Ok, I have been watching this build quietly in the background. (i'm a lurker) Anyway, a few comments. Fantastic job. love the color scheme and attention to detail. What got me to post this was a bit of advice (if this has already been in your mind...disregard and don't take offense plz.) I have sleeved some cables and when I did my first few, I made a couple slight oversights. The one that I would like to bring up is triggered by your choice of pattern on your picture. I was all excited to get to my project and jumped right into it. I forgot to take into account the plug orientation when using the same pattern as you. (Primary color with a single accent color) What I did...finished it all up, and then plugged in my 6 pin PCI-E cables only to find the accent color was on the bottom, (or in the case of the 24pin, on the inside of the cable bends) not visible, thus completely making my accent color useless. Like I said, this being your first cable job, it is something that can be overlooked very easily. Hopefully, you were already aware of this or read this before you screw up like I have done. Keep going, can't wait to see the complete, finished build. A+ Job
SpeedBump613 is offline
