[Scratch] Oak PC case, "Durandal" - Page 7 - Overclock.net
post #61 of 318 Old 02-18-2013, 03:47 PM - Thread Starter
Case Modder
KillThePancake's Avatar
Quoted: 0 Post(s)
Liked: 18
So I think I found what radiator I'm going to use: http://www.xoxide.com/phobya-xtremequad480-radiator.html
With the dimensions, I should be able to mount it in the front, if not, I'm going to find a way to mount it in sideways.
Yesterday's Pancakes, today.
-Egami
My Scratch build log: Durandal
My current build log (WIP): Larry
KillThePancake is offline
post #62 of 318 Old 02-18-2013, 03:51 PM
HPE1000's Avatar
Quoted: 0 Post(s)
Liked: 228
HPE1000 is offline
post #63 of 318 Old 02-18-2013, 04:09 PM
Intel Overclocker
ivanlabrie's Avatar
Location: Buenos Aires, Argentina. Land of the obscenely expensive hardware
Quoted: 0 Post(s)
Liked: 342
ivanlabrie is offline
post #64 of 318 Old 02-18-2013, 04:39 PM
ATI Enthusiast
cards525's Avatar
Quoted: 0 Post(s)
Liked: 1
this build man..
cards525 is offline
post #65 of 318 Old 02-18-2013, 09:11 PM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 18
Originally Posted by HPE1000 View Post
drool.gif and it doesn't cost much either.
Exactly!!
Originally Posted by ivanlabrie View Post
Originally Posted by cards525 View Post
this build man..
-Egami
post #66 of 318 Old 02-19-2013, 02:35 PM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 18
So guys, it looks like im going to be extending the case by a half inch on each side. Making it wider, that is, for the radiator I want to use. I worked it out in Sketchup today, and I would only have 9/64" of space between the rad and the edge of the case :/ I wish I would have known about this radiator from the start of the build. Oh well, I just hope I don't mess this up tongue.gif I'm going to see what scraps of oak I can scrounge, and possibly use some of my wood I bought. I hope everything goes well biggrin.gif
-Egami
post #67 of 318 Old 02-19-2013, 02:56 PM
ATI Enthusiast
cards525's Avatar
Quoted: 0 Post(s)
Liked: 1
Good luck and send us more por... I mean pictures!
cards525 is offline
post #68 of 318 Old 02-19-2013, 03:44 PM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 18
-Egami
post #69 of 318 Old 02-19-2013, 04:57 PM - Thread Starter
Case Modder
Quoted: 0 Post(s)
Liked: 18
So originally I was thinking of adding pieces to the sides, but I realized I can add a piece in the middle, if I just cut the pieces right in the center. The cool thing about this is I will be able to put an "accent" stripe down the center of the case. I also may be able to do some laser engraving as well. I will load up some Sketchup pictures tomorrow.
-Egami
post #70 of 318 Old 02-19-2013, 05:47 PM
Intel Overclocker
ivanlabrie's Avatar
Quoted: 0 Post(s)
Liked: 342
Sounds good...You gonna use a clear panel on the side and have a middle section of wood in between?
