[Build Log] Project Orange Hot Rod- WC'ing a CaseLabs BH7 - Page 2 - Overclock.net
post #11 of 139 Old 05-13-2016, 03:23 AM
Gilles3000's Avatar
Quoted: 0 Post(s)
Liked: 287
Subbed!
Gilles3000 is offline
post #12 of 139 Old 05-13-2016, 08:00 AM - Thread Starter
WaterCooler & Modder
Bear907's Avatar
Quoted: 0 Post(s)
Liked: 44
Originally Posted by DrockinWV View Post
Sounds like fun count me in
Originally Posted by kayan View Post
Subbed.
Originally Posted by Xclsyr View Post
Originally Posted by Wolfsbora View Post
Originally Posted by DapperDan795 View Post
Subbed!
Originally Posted by Reiep View Post
Orange + new Case Labs case = I'm here.
Originally Posted by Gilles3000 View Post
Subbed!
Thanks guys, welcome aboard!'
Originally Posted by alltheGHz View Post
Looks good already, I like the orange/black look. I suggest sleeving some cables while waiting for the case, I know that these things will ship out faster than any other case, but the time is still nice to do some custom work, especially like sleeving, it being so time consuming.
I agree. The worst part of any build is the waiting. I've got a number of things on order, but I'll get what I can done ahead of time. The cables will be sleeved in orange and black paracord. Something similar to this pattern:
Originally Posted by bukkit View Post
i'm subscribing to this, i'd like to see how you do a loop. i'm interested in getting a bh7 in the future, but it depends on the loop for me.
I've got the loop planned out a few different ways. I probably won't make up my mind until I see the case in person and can do a few mock ups. A loop will fit, you just need to be . . . creative. Speaking of, nobody has commented on if they'd like to see the loop contained within, or have it slightly explode from the case. Thoughts?
Originally Posted by spinFX View Post
Woah, gonna squeeze an E-ATX board in that little case, nice!
keen for the build pics.
Warning: Spoiler! (Click to show)
Would you consider making some alternative handles for this case as part of the build? I reckon they don't suit the case that well (the case is quite square cut on the ends, whereas the handles are very rounded, and the curve of the handles doesnt match the curve of the case.
Below i've done a basic 3d render of what I'm talking about... These handles wouldn't be as comfortable to hold (although a bit of padding on the inside of them should help a lot) as the ones that come with the case, but should be good enough to move the case around without much trouble.
I was thinking they could be machined from metal and finished to look like the rest of the case.
its all about the sharp edges and the radius of the corners with this case, and i reckon the handles should match tongue.gif
Only a regular ATX, which is still a lot of room used up in this case. An EATX would fit according to CaseLabs, but you wouldn't have any room on the front of the case to run tubes into the lower section from what I can estimate.
A lot of my build plans are based on measurements done throughout CaseLabs' build process the past several months on this line. I won't be able to confirm plans until I have hands on. My last case, the M8, had space for days so it wasn't an issue. With the BH7, it is so tight, it comes down to a game of millimeters.
I agree about the handles. I ordered the ones from CaseLabs to see how they look, but we'll see. If they don't match, I'll have some made. I've also got some aluminium case feet I'll be throwing on here for a little extra bling on the outside.
`Bear
Work Log - Project ORANGE Hot Rod - a water cooled CaseLabs BH7 build
Bear907 is offline
post #13 of 139 Old 05-13-2016, 08:47 AM
PC Gamer
bukkit's Avatar
Quoted: 0 Post(s)
Liked: 1
i think having the res on the outside would look cool, if there isn't enough space on the inside. could be easier to fill/drain too. what parts are you going to get for your loop? are you doing acrylic? i'm thinking of getting a monsoon mmrs set in the future.
bukkit is offline
post #14 of 139 Old 05-13-2016, 09:38 AM - Thread Starter
Bear907's Avatar
Quoted: 0 Post(s)
Liked: 44
Both ideas would keep all the wiring in the top compartment very minimal to leave room for showing off the tubing. The pump would be located in the bottom compartment along with a fan controller if I can find one that fits. per CaseLabs, there is only about 140mm ish from the top of the mobo to the top of the case. I don't want to fill up the whole thing as then you couldn't see much thru the windows. So . . .
In the "clean" look, I would go with something like the XSPC EX240 low profile. It comes in at about 35.5 mm deep. Along with the Cougar fans I'll be using at 25 mm, that leaves me with about 80-85 mm of space left for tubing and viewing of the board. I could get a micro res and put it in the lower compartment, or get like a 40mm-50mm cylinder res and mount it in the upper compartment - probably on one of the 120 front fans.
or
In the "wild" look, I'm eyeballing the Coolgate copper res which I love the look of! Especially when paired with the Cougar fans. For a res for this look, I'd probably go with one of the primochill phase 2 amber cylinders, or maybe spring for a frozenq cylinder res - the last one I used from them has lasted me over 4 years without an issue.
I can run this one of two ways - mount the radiator on top of the mounting bracket, meaning cutting a large whole in the case skin, fans on the underside of the bracket (inside the case) and then a res on top of the rad. This is pretty aggressive, but you'd be able to see the sides and top fins of the res, as well as the reservoir on top. Could be interesting.
The other option is to mount the rad and fans on the mount inside the case, and then mount the res on top of the bracket. You wouldn't see the top fins of the rad, and the copper sides would be down inside the case. The res would still be poking up out of the top, but it wouldn't be as drastic. I'd then look to have tubing come in and out of the case in a few spots for a unique look.
For both looks, I'll be doing regular "soft" tubing as I already have a ton of black compression fittings. I'd considered doing a hard acrylic tubing, but I do have a budget and didn't want to spend a chunk of it on new fittings when I have plenty of the compression ones already.
I'm sorry if it's hard to visualize, but those are the two main ideas so far. I haven't ordered a new res or rad yet until I figure out which way I want to jump.
~Bear
Bear907 is offline
post #15 of 139 Old 05-13-2016, 09:43 AM
Overclock.net Podcast: LIVE
Wolfsbora's Avatar
Quoted: 0 Post(s)
Liked: 139
I'm really curious how that orange will work with the copper. I hope that you're ready to take some awesome pics! biggrin.gif
Consoles: Atari - 2600 & 7800, Lynx 2; Mattel - Intellivision II; Magnavox - Odyssey 300 & 500; Nintendo - NES, NES Top loader, SNES, N64, GameCube, Wii, Micro Vs. System (Boxing), GameBoy Advance/SP (001)/Micro, DS, 3DS XL; Sega - Master System, Genesis (Gen 1 & 2), 32x, Saturn, Dreamcast; Sony - PS, PS One, PS2, PS2 Slim, PS3, PSP - LE MGS (green); Microsoft - Xbox 360 (1st & 2nd gen); NEC - PC Engine Core Grafx 1; Panasonic - 3DO; SNK - Neo Geo AES MAX 330 MEGA PRO-GEAR SPEC; Texas Instruments - TI-99/4A (both beige & silver); Tandy - TRS-80; Apple - IIc
Arcade: Atari - Centipede & Millipede (full-size); Nintendo - Donkey Kong Junior (cocktail); Midway - GORF (cabaret) & High Impact Football (operator conversion in a full-size, 4-player Atari Gauntlet); Stern - METEOR
Wolfsbora is offline
post #16 of 139 Old 05-13-2016, 09:50 AM - Thread Starter
Bear907's Avatar
Quoted: 0 Post(s)
Liked: 44
I think I'm one of the few people around that still has a camera that was built to just be a camera! I hope the copper and orange mix well if I go that road, but who knows, it could be hideous in person . . . if that turns out to be true, i can default back to a traditional black rad. After talking it out a bit here, I'm starting to lean towards the "wild" look a bit more
Bear907 is offline
post #17 of 139 Old 05-13-2016, 09:51 AM
PC Gamer
JCArch's Avatar
Quoted: 0 Post(s)
Liked: 13
Any chance you want to be my guinea pig and try to fit a 280mm rad in this case? biggrin.gif Looks like it will be awesome, though! I can't wait for these guys to ship out so we can get a glimpse of them with some serious guts.
JCArch is offline
post #18 of 139 Old 05-13-2016, 09:58 AM - Thread Starter
Bear907's Avatar
Quoted: 0 Post(s)
Liked: 44
a 280 could fit. . . maybe. I think you'd have to either modify the top bracket and not use a fan on the front of the case, but it is probably doable. Post pics when you make it happen!
Yeah I can't wait for them to ship. It's one thing to theory craft, but it will all come together once the cases are in hand. I'm looking forward to seeing what everyone does with them.
Bear907 is offline
post #19 of 139 Old 05-13-2016, 01:17 PM
PC Gamer
JCArch's Avatar
Quoted: 0 Post(s)
Liked: 13
Exactly, it seems like no matter how much I plan on paper via pictures the actuality of assembling everything inside of the case is a completely different animal.
Since this line of cases is a bit more "accessible" price-wise, I think we'll see a great variety of mods & build complexity.
JCArch is offline
post #20 of 139 Old 05-13-2016, 03:32 PM
Amiga 500
TUFinside's Avatar
Quoted: 1 Post(s)
Liked: 53
CREATOR: gd-jpeg v1.0 (using IJG JPEG v80), quality = 90
A Clockwork Orange (Kubrick's movie) could have been a nice name too.
TUFinside is offline
