Project: Three Mile Island - Rev. C3 - Page 3 - Overclock.net
post #21 of 52 Old 01-11-2006, 12:27 PM - Thread Starter
WaterCooler
Quoted: 0 Post(s)
Liked: 149
OK, I've given in to temptation - last night I ordered a Clear Danger Den Dual 5.25" Bay Reservoir, as its 1. going to make the routing of my tubing ALOT easier, 2. bleed faster than the t-line with the G5 (whenever air passes through the jet plate it literally gets turned into foam), and 3. it fills in the 2 extra 5.25 bay slots that I have no other use for
but judging by my last DD bay res i had in my very first rig, I should be just fine with it, as DD doesn't use cheap thin acrylic like most other mfg's do
CrimsonMango is offline
post #22 of 52 Old 01-14-2006, 07:13 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 137
Wow, you have lots of money to spend.
Wat profession are you in?
Brakes are for noobs. You just throw it in reverse if you wanna stop!
Driving has less impact on enviroment than walking?
Product Design Portfolio website: www.scupham.com
Ace of Spades is offline
post #23 of 52 Old 01-14-2006, 11:35 AM - Thread Starter
WaterCooler
Quoted: 0 Post(s)
Liked: 149
i work in the dairy dept. at the local grocery store making $7/hr ($7.50 next month) - i'll be 17 on 1/29
post #24 of 52 Old 01-18-2006, 04:35 PM - Thread Starter
WaterCooler
Quoted: 0 Post(s)
Liked: 149
got my DD dual bay reservoir in from CrazyPC.com today (props to them for actually having it IN STOCK! - no one else had the clear ones)
and got the new WC loop with the DD ATI-X18 full cover block set up, with ABSOLUTELY NO LEAKS when i first filled it up and turned on the pumps
[img]http://www.*******.com/sneaky/p3mic3/nwc1.jpg[/img]
[img]http://www.*******.com/sneaky/p3mic3/nwc2.jpg[/img]
[img]http://www.*******.com/sneaky/p3mic3/nwc3.jpg[/img]
i also got another paycheck (w00teh!) so as soon as guava gives me the thumbs up, off goes payment for the tasty 955XE
post #25 of 52 Old 01-20-2006, 05:24 PM - Thread Starter
WaterCooler
Quoted: 0 Post(s)
Liked: 149
got some stuff from performance-pcs.com that i ordered for a friend and tossed some red & green 5mm LED's on with it to replace the two dead blue ones for power/hdd on the front of the case
[img]http://www.*******.com/sneaky/p3mic3/fled.jpg[/img]
post #26 of 52 Old 01-20-2006, 05:33 PM
Laptop Repair Guru
Quoted: 0 Post(s)
Liked: 376
Looks awesome!! Any temps diff after the res?
Tuner- HP Branded Adaptec AVC-3610 USB w/Dual Tuners | Microsoft MCE Remote
HTPC- Dell Inspiron 700M
P4 560 ES@ 4.4|P4 640@ 4.017|3700+@2.53 1.4v
steveo42024 is offline
post #27 of 52 Old 01-23-2006, 02:21 AM - Thread Starter
WaterCooler
Quoted: 0 Post(s)
Liked: 149
nope - no temp. difference from the res - the water in the system all equalizes to the same temps, having more water in the system just makes equilbrium take longer to occur
i mainly got the res to aid in the routing of tubing - without it, if i tried to go from the X18 block to the pump, its basically impossible without 3 feet of tubing
post #28 of 52 Old 01-23-2006, 02:26 AM
Overclocker
-Jeppe-'s Avatar
Quoted: 0 Post(s)
Liked: 52
what temps are you getting with the X1800
Chimp Challenge 2 x Participant  1 Million+ Folding at Home points
-Jeppe- is offline
post #29 of 52 Old 01-24-2006, 08:36 PM - Thread Starter
WaterCooler
Quoted: 0 Post(s)
Liked: 149
sub-40ºC temps @ full load
anyways, 955XE is on its way to me via USPS express mail (overnight), and i also got in some red/green 5mm LED's to replace the red/blue ones on my sunbeam fan controller, plus the power bridge for the ATI-X18 block came from DD
[img]http://www.*******.com/sneaky/p3mic3/ledbridge.jpg[/img]
post #30 of 52 Old 01-24-2006, 09:49 PM
Audiophile
Remonster's Avatar
Quoted: 0 Post(s)
Liked: 316
Oh my god this is shaping up quite awesomly, I can't wait to see what that Presler will do with a proper custom water cooling setup like yours. Since you seem to be made of money (lol) are you going to get a X1900XTX now that they are out on newegg?
Remonster is offline
