Project Three Mile Island - Rev. D1 (Oh God!) - Overclock.net
post #1 of 4 Old 02-20-2006, 09:57 AM - Thread Starter
WaterCooler
Quoted: 0 Post(s)
Liked: 149
[img]http://www.*******.com/sneaky/p3mid1/revd1_logo.jpg[/img]
**Sigh** Looks like Sneaky’s at it again – this time with a custom case from Mountain Mods, plus a few other new toys and mods thrown into the mix as always
This time around I went into a little more detail with the spec/supply list, but hey, now you can follow me with the uber-tiny little details that I pay attention to
Planned Specs:
Case/Components:
-Enclosure: Custom “Black Wrinkle” Powdercoated Mountain Mods U2-UFO w/ Original Top modded for vertical 120.3 and horizontal 120.2 Thermochill PA series radiators - NEED
-Processor: Intel Pentium D 955XE ES Presler - HAVE
-Motherboard: Asus P5WD2-E Premium 975X - NEED
-Memory: 2GB (2x1GB) OCZ DDR2-667/PC2-5400 Platinum Enhanced Bandwidth - HAVE
-Graphics: Sapphire ATI Radeon x1900 Crossfire Edition 512MB PCI-Express x16 - NEED
Sapphire ATI Radeon x1900XTX 512MB PCI-Express x16 - HAVE
-Audio: Creative Sound Blaster Audigy 2 ZS - NEED
-Storage: 2x Hitachi Deskstar T7K250 250GB 7200RPM 8MB cache SATA II (RAID 0) - HAVE
Seagate 120GB 7200RPM 8MB cache IDE (backup drive) - HAVE
-5.25 Device: Black Plextor PX-716AL Slot Load Dual Layer DVD±R/RW CD-R/RW - NEED
-3.5 Device: Black Sony 3.5" Floppy - HAVE
-Power: PC Power & Cooling TC1KW 1kW SLI/EPS Power Supply - NEED
CPU Cooling:
-CPU Block: Little River Water Blocks Storm G5 - HAVE
-CPU Radiator: Thermochill PA 120.3 Radiator - NEED
-CPU Pumps: 2x Swiftech MCP-655 Pumps - HAVE
-Fillport/Reservoir: Clear Danger Den Single 5.25" Bay Reservoir - NEED
-Tubing: Masterkleer 1/2" ID, 13/16" OD (5/32" Wall) Tubing - HAVE
-Hose Clamps: 10x 316 Stainless Steel Worm Drive Hose Clamps 1/2" band 7/8" max. ID - HAVE
GPU Cooling:
-GPU Blocks: 2x Danger Den Low Profile Acetal Maze4’s - NEED
-GPU Radiator: Thermochill PA 120.2 Radiator - NEED
-GPU Pump: Swiftech MCP-655 Pump - NEED
-Hose Clamps: 16x 316 Stainless Steel Worm Drive Hose Clamps 1/2" band 7/8" max. ID - NEED 6
-Fittings: 2x Clear Polypropylene “Y” Fittings - HAVE
Misc. Cooling:
-Northbridge Chipset Cooler: ThermalRight NB-1C w/ Delta 45x10mm fan - HAVE
-Southbridge Chipset Fan: Delta AFB0412M 40x10mm fan - HAVE
-CPU Radiator Fans: 6x Black Yate Loon D12SL-12 120x25mm fans- NEED
-GPU Radiator Fans: 4x Black Yate Loon D12SL-12 120x25mm fans - NEED
-Case Fans: 5x Black Yate Loon D12SL-12 120x25mm fans - NEED
-RAMsinks: 16x Copper OCZ BGA RAMsinks - NEED
Miscellaneous Parts:
- Matched “Black Wrinkle” Powdercoated Sunbeam 5.25" 4-Channel Rheobus - NEED
-Matched “Black Wrinkle” Powdercoated Aluminum Lian Li 3.5 to 5.25 Bay Converter - NEED
-Matched “Black Wrinkle” Powdercoated Aluminum Lian Li Floppy Drive Bezel - NEED
-5x Matched “Black Wrinke” Powdercoated Stainless Steel Lian Li PCI Cover Plates - NEED
-10x Black 120mm Wire Fan Grills - HAVE
-3x Green Logisys 12" Dual CCFL Kits + custom triple-switch PCI plate - HAVE
-2x Lian Li V-series Stainless Steel Power Buttons - NEED
-5x Water Clear Pure Green 5mm LEDs - HAVE
-5x Water Clear Pure Red 5mm LEDs - HAVE
-10x Chrome Mountain Mods 5mm LED Bezels - NEED 5
Wiring & Wire Management:
-1x Black Rounded 18" Dual IDE Cable - NEED
-1x Black Rounded 10" Floppy Cable - NEED
-10x 12” 3-pin extension cables - NEED
-10x 3-pin “Y” connectors - NEED
-5x 4-pin molex “Y” connectors - NEED
-5x 3 to 4-pin molex connectors/adapters - NEED
-10 feet Black FLEXO PET 1/8" Sleeving - NEED
-50 feet Black FLEXO PET 1/4" Sleeving - NEED
-50 feet Black FLEXO PET 3/8" Sleeving - NEED
-10 feet Black FLEXO PET 1/2" Sleeving - HAVE
-8 feet Black Polyolefin 1/4” Heat Shrink Tubing - NEED
-16 feet Black Polyolefin 3/8” Heat Shrink Tubing - NEED
-16 feet Black Polyolefin 1/2” Heat Shrink Tubing - NEED
-4 feet Black Polyolefin 3/4” Heat Shrink Tubing - NEED
-500x Black Nylon 4” (5/8” bundle) Cable Ties - NEED
-100x Black Nylon 3/4” 4-way Adhesive-Backed Cable Mounts - NEED
-1x Black AC Ryan Connectx ATX 24-pin Female connector housing - NEED
-1x Black AC Ryan Connectx EPS 8-pin Female connector housing - NEED
-1x Black AC Ryan Connectx Floppy Power 4-pin Female connector housing - NEED
-50x Black AC Ryan Connectx 3-pin Female fan housing - NEED
-40x Black AC Ryan Connectx Male 4-pin Molex Housing - NEED
-50x Black AC Ryan Connectx Female 4-pin Molex Housing - NEED
Miscellaneous Hardware:
-3x Sets of 10 Black Mutant Mods 6-32 threaded Thumb Screws - HAVE 2 Sets
-100x Neoprene Cushioning & Sealing Washer #10 Screw Size, .170” ID, ½” OD, .93” Thick - HAVE
-200x Black Oxide Alloy Steel Button Head Socket Cap Screw 8-32 Thread, 5/8" Length - NEED
-100x Black Oxide Alloy Steel Button Head Socket Cap Screw 8-32 Thread, 1/2" Length - NEED
-200x Black Oxide Alloy Steel Button Head Socket Cap Screw 6-32 Thread, 1/4" Length - NEED
-100x Black Oxide Alloy Steel Button Head Socket Cap Screw 4-40 Thread, 1/4" Length - NEED
-50x Black Oxide Alloy Steel Button Head Socket Cap Screw 6-32 Thread, 5/16" Length - NEED
-100x Black Oxide Class 10.9 Steel Button Head Socket Cap Screw M3 Size, 8 mm Length, .5 mm Pitch - NEED
-100x Black Oxide 18-8 Ss Machine Screw Hex Nut 8-32 Screw Size, 11/32" Width, 1/8" Height - NEED
-100x Black Oxide 18-8 Ss Machine Screw Hex Nut 6-32 Screw Size, 5/16" Width, 7/64" Height - NEED
-Clear Hard Anodized Alloy 6061 Aluminum Rod, 1/4" Diameter, 3' Length - NEED
Welcome to Project Three Mile Island - Revision D1
-Justin
CrimsonMango is offline
post #2 of 4 Old 02-20-2006, 10:03 AM
4.0ghz
13 3 @ 7 l 3 13 0 y's Avatar
Quoted: 0 Post(s)
Liked: 236
does that mobo support crossfire?
it will say in the title
EDIT:nope, it doesnt support CF
13 3 @ 7 l 3 13 0 y is offline
post #3 of 4 Old 02-20-2006, 10:06 AM - Thread Starter
WaterCooler
Quoted: 0 Post(s)
Liked: 149
yup, both the 955X and 975X chipsets fully support crossfire
post #4 of 4 Old 10-01-2010, 09:26 AM
Commodore 64
briansparks0211's Avatar
Quoted: 0 Post(s)
Liked: 0
That's a great computer for 2006! Back then, the computer cables definitely had coatings to protect from vibration and chemical reaction. The PFA properties of cables from http://fluorotherm.com/Properties-PFA.asp are among the best, as well as their heat shrink tubing.
briansparks0211 is offline
