Where can I get U-channel molding and sound dampening foam for cheap? - Overclock.net
post #1 of 11 Old 12-01-2012, 01:33 AM - Thread Starter
1.7ghz
wompwomp's Avatar
Quoted: 0 Post(s)
Liked: 15
Lots of pc shops carry this stuff but charge a kidney and a liver... They really shouldn't be charging that much for what it actually is.
wompwomp is offline
post #2 of 11 Old 12-01-2012, 02:10 AM
d-block's Avatar
Quoted: 0 Post(s)
Liked: 233
Go to a Lowe's or hardware store. You should be able to find what you're looking for there.
7 Million+ Folding at Home points  Foldathon Folder - 2013 Participant
d-block is offline
post #3 of 11 Old 12-02-2012, 12:42 AM - Thread Starter
1.7ghz
wompwomp's Avatar
Quoted: 0 Post(s)
Liked: 15
Even the sound dampening foam?
wompwomp is offline
post #4 of 11 Old 12-02-2012, 12:49 AM
Case Modder
AlderonnX's Avatar
Quoted: 0 Post(s)
Liked: 53
U-Channel http://www.bestbyte.net/merchant/merchant.mvc?Screen=PROD&Store_Code=BB&Product_Code=CACM01CSM&Category_Code=CACM
Thats where Evil Jerry and myself and a bunch of others get it it.
And the foam
http://www.moddiy.com/products/Premium-Wave-Noise-Dampening-Foam-(50x50cm).html?gclid=CMm1i9Gd-7MCFQhyQgod73oA1A#.ULsHs4PSL3A
I buy alot of stuff from MODdiy.. they charge about the same to ship as the price of the item from hong kong But its cheap!!!
Cheers, Alder
AlderonnX is offline
post #5 of 11 Old 12-02-2012, 12:51 AM
Ma15's Avatar
Quoted: 0 Post(s)
Liked: 11
You can get the sound dampening from places like quietpc or moddiy
The u-channel you can get from places like mnpctech from bill owen.
Ma15 is offline
post #6 of 11 Old 12-02-2012, 12:51 AM
Pigeon Loyalist
wholeeo's Avatar
Quoted: 0 Post(s)
Liked: 254
http://www.mcmaster.com/
http://www.mcmaster.com/#catalog/118/3769/=kewd0r
I personally went with 8510K11 SBR Rubber Edge Trim, 1/32" Opening, 5/32" Inside Depth, 10' Length
{CPU} i7-7700K @ 5.2/4.8@1.395v {MB} Asus Z270G MATX {Ram} EVGA SuperSC 16GB DDR4 3200 @ 3600
{GPU} Zotac GTX 1080 {Case} TT P3 {PSU} Evga SuperNova 1200W P2 {Fans} Corsair ML120 Pros
{Rads}EKWB XE 360 {Pump} EK-XRES 140 Revo D5 {Blocks} EKWB Nickel Plexi GPU & CPU Blocks
{Monitors} Acer XB270HU (G-Sync) & Asus PB278Q {Keyboard} Corsair K70 Reds {Mouse} EVGA Torq X5 Optical
wholeeo is offline
post #7 of 11 Old 12-12-2012, 12:30 AM
Windows Wrangler
t45457523's Avatar
Quoted: 0 Post(s)
Liked: 3
can you buy from here without a company?
t45457523 is offline
post #8 of 11 Old 12-12-2012, 12:39 AM
SDH500's Avatar
Quoted: 0 Post(s)
Liked: 16
It is unfortunate that they no longer ship residential, I am sure someone like myself would help you out and get it shipped with one of our orders. What are communities for. Just one thing though, we would need to know where your located.
SDH500 is offline
post #9 of 11 Old 12-12-2012, 01:44 AM
Windows Wrangler
t45457523's Avatar
Quoted: 0 Post(s)
Liked: 3
do you live in the USA? and what i was looking at was a bunch of screws, bolts, sheet metal, and heatshrink
post #10 of 11 Old 12-12-2012, 10:51 AM
SDH500's Avatar
Quoted: 0 Post(s)
Liked: 16
No unfortunately I live in Canada, if I bought something for you and shipped it back across the boarder is would cost over $20 in shipping for small letter sized packages.
SDH500 is offline
