UltraGamer Desk - built in PS3, Xbox, and PC Liquid Cooled. - Page 5 - Overclock.net
post #41 of 47 Old 04-29-2013, 12:12 PM
1.3ghz
bowmanvmi's Avatar
Quoted: 0 Post(s)
Liked: 7
Originally Posted by Jollyriffic View Post
Failure! $55 wasted.. i need to hit a scratch off lotto ticket so i can buy what i need to do this right.
Ouch. Have you thought of affixing the acrylic to some sort of support/bracket to create your "box", or whatever you're going for? I created something semi-similar, a desk-case, in which I screwed the acrylic directly to the support:
bowmanvmi is offline
post #42 of 47 Old 04-29-2013, 02:38 PM
333mhz
phxtravis's Avatar
Quoted: 0 Post(s)
Liked: 7
That looks pretty awesome, industrialish. Have any more pics?
Any updates OP?
phxtravis is offline
post #43 of 47 Old 04-30-2013, 02:37 PM
1.3ghz
bowmanvmi's Avatar
Quoted: 0 Post(s)
Liked: 7
Any updates OP?
They're in my "Crystal" build that's in my signature. Only three pics though.
post #44 of 47 Old 05-08-2013, 02:26 PM - Thread Starter
Case Modder
Jollyriffic's Avatar
Quoted: 0 Post(s)
Liked: 57
no sorry, no update.
after destroying that sheet of acrylic i'm waiting to have the funds for
http://www.amazon.com/gp/product/B003GUESEU/ref=pe_62810_29669420_email_1p_0_ti
and another sheet.
called every glass place around here and they don't do bending at all.
strange thing is they are all also more expensive for the same sheet thickness/size vs Lowes
lowes wants $55 and everyone else is pretty much $65 - $75.
Jollyriffic is offline
post #45 of 47 Old 05-10-2013, 06:06 AM
ilm121209's Avatar
Quoted: 0 Post(s)
Liked: 0
awesome idea!
ilm121209 is offline
post #46 of 47 Old 05-29-2013, 06:35 PM
ibleedspeed's Avatar
Quoted: 0 Post(s)
Liked: 7
have you thought of not bending and just cutting seperate sheets to screw down? there is no way you will get a good bend on a piece that large. only a plastic fabrication shop can do that. there is one here in houston i think that can fab anything out of acrylic. good luck man.
ibleedspeed is offline
post #47 of 47 Old 08-13-2013, 01:06 PM
pozativenrgy's Avatar
Quoted: 0 Post(s)
Liked: 4
pozativenrgy is offline
