Unhappy with the loose, squeaky doors on the TT Armor? cheap fix inside! - Overclock.net
post #1 of 7 Old 04-06-2006, 07:50 PM - Thread Starter
4.0 GHz
Quoted: 0 Post(s)
Liked: 73
I decided to put together a little walk through as to what i did about these doors (flaps) being loose and squeaking. This is a very easy and cheap fix (.20) and can be done within a few minutes.
It works very well at keeping the flaps open at any position you want them and also stops the squeeking. I am not sure if anyone else came up with this idea before but here we go. Also i included pictures as links so dial up users would'nt have trouble viewing this thread.
1) You will need two small rubber (or nylon) washers. I used rubber 5/32x3/8x1/16.
http://i5.photobucket.com/albums/y17...r/3b28cd93.jpg
2) Locate the top bracket and remove the two screws and bracket. You only need to remove the top bracket on each side to get this done.
http://i5.photobucket.com/albums/y17...r/38695056.jpg
3) Slide the flap out a little and lift up to remove the flap. Locate the bottom peg on the bottom bracket and slide a rubber washer all the way on.
http://i5.photobucket.com/albums/y17...r/1a426992.jpg
4) Replace the flap and top bracket and repeat with the other side. There you have it! A very cheap and easy fix that works very well and you cannot even tell a mod has been done. Enjoy!
Thumper and MjrTom like this.
xF5x is offline
post #2 of 7 Old 04-07-2006, 03:10 AM
Case Modder
FoRmEd's Avatar
Quoted: 0 Post(s)
Liked: 209
Very innovative! I'm impressed
FoRmEd is offline
post #3 of 7 Old 04-07-2006, 07:02 AM - Thread Starter
4.0 GHz
Quoted: 0 Post(s)
Liked: 73
Thanks, lol. It did'nt take a major brain storm to figure this out and i am sure others must have thought of this already.
I just hear of so many people complaining about the doors (flaps) being loose and what not then decide to take them off. I personally like the doors as they do somewhat look ok and protect the front of the case along with the drives if you decide to slide your chair into the front of the case by accident.
Just a simple idea for those who like the doors and want to keep them on.
FoRmEd likes this.
xF5x is offline
post #4 of 7 Old 04-07-2006, 07:04 AM
Over the Pond...
MjrTom's Avatar
Quoted: 0 Post(s)
Liked: 318
Good job Buddy
Half the fun of having a pc is never leaving it alone
post-flame-small.gifP4: 3600MHz - P4 2.4c Gallatin Core - ABIT IC7 - 1GB BH-5 - 2.5-3-2-6 2.8vpost-flame-small.gif
post-flame-small.gifAMD64: 3105MHz Opty 165 CCBBE - DFI SLI-D - Mushkin Redline @DDR518 3-3-2-8 SuperPi 1M= 27.540 secs post-flame-small.gif
post-flame-small.gif2nd Rig:AOpen EZ462 SFF - AMD 3700+ - 6800GT 256MB - 2x512MB (BH-5) - 120MB SATA DM9+ - NEC SATA DVD/RWpost-flame-small.gif
post-flame-small.gif3rd Rig:Toshiba Satelite L30 - Intel Celeron-M 440 (1.86GHz 1MB L2) - Super Talent 2GB PC2 4200 (5-5-5-15) - Toshiba 60GB 5400rpm SATA II (PMR Drive) - ATI X200M - Vista Home Basicpost-flame-small.gif
1.536 TB of HDD Storage and climbing....
MjrTom is offline
post #5 of 7 Old 04-07-2006, 07:10 AM - Thread Starter
4.0 GHz
Quoted: 0 Post(s)
Liked: 73
Originally Posted by MjrTom
Good job Buddy
Thanks!
Yeh, my wife says i mess with my pc more than i mess with her, lmao. This stuff is so addicting i just got done building one and want to build another .
xF5x is offline
post #6 of 7 Old 04-07-2006, 07:15 AM
Over the Pond...
MjrTom's Avatar
Quoted: 0 Post(s)
Liked: 318
I get exactly the same comments from mine LMAO!
Yeah modding is very addictive esp when you see what other people have done with theirs and it opens up new ideas to ponder....
MjrTom is offline
post #7 of 7 Old 04-07-2006, 12:15 PM
Case Modder
FoRmEd's Avatar
Quoted: 0 Post(s)
Liked: 209
Well
The Wife doesnt know till I already have the stuff
but doesnt care because I do it so fast... AND she gets hers.
FoRmEd is offline
