What Size Drill Bit? - Overclock.net
post #1 of 12 Old 04-11-2006, 04:15 PM - Thread Starter
Original OCN Gangsta
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
Okay, one for all you machinists out there, what size drill bit do I need to get for a #10-32 * 1/2" bolt? It's gotta be able to drill through aluminum, and possibly if it's available thru Home Depot.
Thanks a bunch guys
My CNC Mill Project
Originally Posted by CyberDruid
Burn + Electricty + Water =
But the man has the patience of a saint...
We cannot change the cards we are dealt, just how we play the hand.
--Randy Pausch
Current Best Benchmark
1 Million+ Folding at Home points
Burn is offline
post #2 of 12 Old 04-11-2006, 04:16 PM
4.0ghz
ItsLasher's Avatar
Quoted: 0 Post(s)
Liked: 583
Here ya go its all you'll ever need. and the bits can be bought at any harware.
If you're not tapping it I'd go the next size up for enough free play to be able to get all bolts in.
Burn likes this.
ItsLasher is offline
post #3 of 12 Old 04-11-2006, 04:19 PM - Thread Starter
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
Nice, do you know what diameter drill bit I need though?
My CNC Mill Project
--Randy Pausch
Burn is offline
post #4 of 12 Old 04-11-2006, 04:21 PM
Audiophile/Car lover
pbasil1's Avatar
Quoted: 0 Post(s)
Liked: 460
If your not tapping the hole, then just slightly larger than the bolt diameter.
Like cars? Carforum!
How to choose the right fan
what is " folding " ???
When you take an old graphics card and effectively 'fold' it in half, in order to remove the chip.This process takes alot of power.
Foldathon Folder - 2011 Participant  Chimp Challenge 2 x Participant  10 Million+ Folding at Home points  Foldathon Folder - 2013 Participant
pbasil1 is offline
post #5 of 12 Old 04-11-2006, 04:22 PM
4.0ghz
ItsLasher's Avatar
Quoted: 0 Post(s)
Liked: 583
Bits that small are numbered or lettered so I'd say just compare the bit to the bolt,It calls for a #21 bit if you're tapping the holes.
post #6 of 12 Old 04-11-2006, 04:23 PM - Thread Starter
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
Yeah, it's not going to be tapped. I tried with 3/16 and a 1/4 bits, but the 3/16 was too small and the 1/4 was too big...Any suggestions on what size bit between?
My CNC Mill Project
--Randy Pausch
Burn is offline
post #7 of 12 Old 04-11-2006, 04:26 PM
4.0ghz
ItsLasher's Avatar
Quoted: 0 Post(s)
Liked: 583
Try a 7\\32 or a 15\\64 the are the only 2 bits between a 3\\16 and 1\\4 that aren't numbered or lettered.
post #8 of 12 Old 04-11-2006, 04:28 PM - Thread Starter
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
Okay, I'll give that a shot. Thanks a bunch!
My CNC Mill Project
--Randy Pausch
Burn is offline
post #9 of 12 Old 04-11-2006, 05:02 PM - Thread Starter
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
It seems that 7/32 is too big by just a bit...Anything minutely smaller?
My CNC Mill Project
--Randy Pausch
Burn is offline
post #10 of 12 Old 04-11-2006, 06:10 PM
TrueNoob's Avatar
Quoted: 0 Post(s)
Liked: 49
try a different screw size...
Sometimes the creation is greater than the creator...
Folding as SlikCoreX (will start again soon)
TrueNoob is offline
