Java Help! - Page 2 - Overclock.net
post #11 of 16 Old 04-10-2008, 02:43 PM
ldk
Overclocker - Duh!
Quoted: 0 Post(s)
Liked: 368
its being called where it says
super.paintComponent(g);
ldk is offline
post #12 of 16 Old 04-10-2008, 02:45 PM
Loading Please Wait...
TheLegend's Avatar
Quoted: 0 Post(s)
Liked: 702
In order for it to be called you need to have the method implemented. The method isn't explicitly stated within that portion of the code.
Fold for 37726
Folding Team "Just Be Cause" Honorary Member
TheLegend is offline
post #13 of 16 Old 04-10-2008, 02:48 PM
ldk
Overclocker - Duh!
Quoted: 0 Post(s)
Liked: 368
ldk is offline
post #14 of 16 Old 04-10-2008, 02:48 PM
Luck++
Quoted: 0 Post(s)
Liked: 417
It still never defines it's value.
Licht is offline
post #15 of 16 Old 04-10-2008, 04:29 PM - Thread Starter
Custom User Title
pauldovi's Avatar
Quoted: 0 Post(s)
Liked: 923
That is the entire code! And there is never a graphics object created or that method called!
There is no Graphics g. It was never created.
pauldovi is offline
post #16 of 16 Old 04-10-2008, 05:44 PM
With great difficulty
Quoted: 0 Post(s)
Liked: 643
Originally Posted by rabidgnome229 View Post
Java does that stuff behind the scenes. When you do something with graphics it makes a new thread which is invisible to you. Somewhere in that thread it creates the graphics object and calls paintComponent. You don't need to know the context in which it is called, but you do need to specify what happens when the call is made
Does my post not count or something? You don't see it, but it's still there. I would guess that g is initialized when the NewPanel constructor is called
The method will be called by the thread that is controlling the display (which is invisible to you by default) every time it wants to update the view. If you want to manually initialize g or manually call paintComponenet you can do so by overriding the default methods/constructors, but there is usually no reason to do so
rabidgnome229 is offline
