Scratch Build Case Club - Page 8 - Overclock.net
post #71 of 1373 Old 03-31-2013, 10:59 AM
Case Modder
adamski07's Avatar
Quoted: 0 Post(s)
Liked: 96
adamski07 is offline
post #72 of 1373 Old 03-31-2013, 11:43 AM
PC Gamer
morencyam's Avatar
Quoted: 0 Post(s)
Liked: 278
Originally Posted by adamski07 View Post
Yup. Just ask urself. Did i buy a case? Or started with a case? If ur answer is yes, then that is case modding.
^this
It wouldn't be from scratch if you started with an existing case, no matter how much you changed it.
Never attribute to malice that which is adequately explained by stupidity
morencyam is offline
post #73 of 1373 Old 03-31-2013, 01:12 PM
FOLDING! FOLD FOLD FOLD!
dman811's Avatar
Location: Folding@Home Section - Man Cave - North Carolina
Quoted: 0 Post(s)
Liked: 120
That's kinda what I figured, but I thought I would let you guys decide that.
Still In Beta Folding Team Captain
post-flame-small.gifProudly Folding For Still In Betapost-flame-small.gifHFM Live Stats
Steam: ctxdemon | Origin: DerickM
Signature Worthy Quotes (Click to show)
I romanced Liara in ME 1.
I last minute romanced Garrus in ME 2.
Then in ME 3 I told Liara we were still together right after telling Garrus the same thing. Progressed on with Liara then (unintentionally) had a shower with Traynor and (intentionally) led on Allers.
So am I a bad person or is my female Shepard just easy?
They didn't get kinky no matter what I did. Disappointment.
dman811 is offline
post #74 of 1373 Old 04-02-2013, 12:19 AM
4.0 GHz
Quoted: 0 Post(s)
Liked: 139
Does anyone have the measurements of the motherboard mounts for all the different sizes?
Answer my own question: found a ATX standard layout for the motherboard, I will post it HERE for everyone to use.
ginger_nuts is offline
post #75 of 1373 Old 04-02-2013, 02:53 AM
somebadlemonade's Avatar
Quoted: 0 Post(s)
Liked: 107
http://www.formfactors.org/developer%5Cspecs%5Cmatxspe1.2.pdf
page 12 for m-atx hole measurements
xl-atx
http://i803.photobucket.com/albums/yy315/kamaster7/Fermi%202/XL-ATX-standoffspacing.jpg
hptx
http://imageshack.us/photo/my-images/687/mbtray.png/sr=1
mini itx uses 4 holes from atx/m-atx/pretty much every formfactor
e-atx(not gamer e-atx like the ROG boards from asus most of those use atx mounting hole layout) page 55
http://downloadmirror.intel.com/18124/eng/D5400XS_TechProdSpec.pdf
if you want to find a form factor i didn't post just search for the form factor you are looking for along with one of the following "mounting hole diagram" or "mounting hole drill diagram" without the quotes of course. . .
i also found this article http://annettekraft.ifunnyblog.com/atxmountingholes/#
ginger_nuts likes this.
somebadlemonade is offline
post #76 of 1373 Old 04-02-2013, 06:39 AM
PC Gamer
morencyam's Avatar
Quoted: 0 Post(s)
Liked: 278
xl-atx
hptx
EDIT: I added a painting guide I used when I was painting the aluminum and acrylic for my case. If you guys have any other links or guide that have helped you, post them add I'll add them to the OP to build up a nice list of helpful resources.
post #77 of 1373 Old 04-02-2013, 07:23 AM
vaporizer's Avatar
Quoted: 0 Post(s)
Liked: 52
xl-atx
hptx
Originally Posted by morencyam View Post
vaporizer is offline
post #78 of 1373 Old 04-02-2013, 11:15 AM
Quoted: 0 Post(s)
Liked: 2
Hello everyone, I'm new to the boards looking around for some info for a future build and this thread drew me in big time. Seeing all of your amazing work has really got me wanting to try my hand at building my own case. What I have in mind is an acrylic design, but I have very little experience working with it. I'm hoping that someone here has had some luck working with it and could give me some pointers or "If I only knew" advice before I jump in head first. Or possibly point me in the right direction to where I can find some good info on working with acrylic. I wish I was a little more artistic so I could draw up a picture of what I have in mind, I think it will be a pretty unique design. smile.gif
Macab0ne is offline
post #79 of 1373 Old 04-02-2013, 11:23 AM
Case Modder
adamski07's Avatar
Quoted: 0 Post(s)
Liked: 96
post #80 of 1373 Old 04-02-2013, 11:56 AM
PC Gamer
morencyam's Avatar
Quoted: 0 Post(s)
Liked: 278
I used a lot of acrylic in my build as well. It's fairly easy to work with. Just a few pointers though. When drilling holes, make sure you put something solid behind it, like a piece of wood, to give it more support so it doesn't crack. If you're using a jig saw to cut, use a high tooth per inch blade and take your time. Going too fast could also cause cracking or breaking. Obviously, the thicker the acrylic, the stronger it will be and less likely to break or crack. And always put down some masking tape or painters tape on the areas you are going to cut to prevent scratches. I learned that one the hard way. Some of the other members of this club have some pretty good build logs I'd suggest taking a look at to get some ideas as well.
