Will it fit? 650D - Vengeance RAM - H100i - 4 fans? - Overclock.net
post #1 of 11 Old 04-18-2013, 08:55 AM - Thread Starter
JaredxShreds's Avatar
Quoted: 0 Post(s)
Liked: 0
Just receieved the 650D along with the H100i. Will it fit at the top of the case with Vengeance RAM?
Next question: Will it fit if I put 4 fans on the rad in push/pull?
Thank you.
JaredxShreds is offline
post #2 of 11 Old 04-18-2013, 09:00 AM
♫♪.ılılıll|̲̅̅●̲̅̅|̲̅̅=̲̅̅|̲̅̅●̲̅̅|llılılı.♫♪
Quoted: 0 Post(s)
Liked: 260
looks ok, but what mother Board? that seems to also be a limiting factor depending on your Mobo layout.
can you also provide a picture?
Overclock.net 10 Year Member
StormX2 is offline
post #3 of 11 Old 04-18-2013, 09:02 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 0
I will when i get home but I do not have the motherboard yet, or the RAM. Havent ordered them yet.
Mobo: ASUS P8Z77-V PRO
post #4 of 11 Old 04-18-2013, 09:10 AM
Quoted: 0 Post(s)
Liked: 260
you might have a problem then
StormX2 is offline
post #5 of 11 Old 04-18-2013, 09:11 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 0
Well I will say this picture still pleases me because you have the fans on top of the rad. Exhaust right? How are your temps with that set up?
post #6 of 11 Old 04-18-2013, 09:14 AM
Quoted: 0 Post(s)
Liked: 260
not my setup, I use google
http://forum.corsair.com/v3/showthread.php?t=97885
here is a thread with someone looking ot do similar, but I dont think he is very specific on the motherboard
honeslty from what I understand, you dont really need to push/pull these. the fans it comes with should be good enough. Not sure which works best for CLC's but Id prefer to do a Pull.
StormX2 is offline
post #7 of 11 Old 04-18-2013, 09:18 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 0
Pull as in, the fans on top, pulling air from the case through the rad and out of the case?
post #8 of 11 Old 04-18-2013, 09:32 AM
Quoted: 0 Post(s)
Liked: 260
yep, might make it easier to pass hot air up and through the top mesh of he case.
otherwise, and I have no idea if this is possible, can you put the fan on the top outside of the case? and use fans under the Rad in Push?
This way you have all the space provided by only have 1 set of fans on the rad in the case, but still have push pull with th pull fans mounted outside?
StormX2 is offline
post #9 of 11 Old 04-18-2013, 09:34 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 0
Im glad, because I wanted to put my fans on top so the LED is visible through the mesh wink.gif
And I might...but that is so godawful looking to me. Hahaha
post #10 of 11 Old 04-18-2013, 09:41 AM
Crimea river
Vlasov_581's Avatar
Quoted: 0 Post(s)
Liked: 540
from my personal experience, if you want push/pull and don't care about looks, you'll need to mount fans on top of the case.......now having said that, I have cleared push/pull with all of the fans on the inside with some motherboards.......primarily you problem will be with the position of the 8pin cpu power connector and top I/o ports......I have repositioned an h100 before by using different case holes on top to get extra clearance
Chimp Challenge Participant  8 Million+ Folding at Home points
Vlasov_581 is offline
