PC Only Boots outside of case - Overclock.net
post #1 of 6 Old 08-06-2013, 10:54 PM - Thread Starter
plugssnotdrugss's Avatar
Quoted: 0 Post(s)
Liked: 0
So I got my PC working and running.... But outside of the case. But the odd thing is it will only boot outside of the case, once I reassemble it in the case and go to boot it, it doesn't boot. Any ideas why?
plugssnotdrugss is offline
post #2 of 6 Old 08-06-2013, 10:58 PM
Quesoblanco's Avatar
Quoted: 0 Post(s)
Liked: 196
Your case is causing a short. My buddy had the same problem. Make sure you are using the MOBO stand offs ( little gold or black thingies), worse case scenario is you RMA the case or get a new one.
Quesoblanco is offline
post #3 of 6 Old 08-06-2013, 10:59 PM
Fishinfan's Avatar
Quoted: 0 Post(s)
Liked: 187
It could a wire that is shorting somewhere in your case.
Did it boot inside your case before?
Fishinfan is offline
post #4 of 6 Old 08-06-2013, 11:04 PM
Intel Overclocker
speedytech7's Avatar
Quoted: 0 Post(s)
Liked: 15
Check to see that your case isn't touching the motherboard other than the stand-offs. This happens generally when front panel connectors get shorted out on the case.
"Overclocking is an art... I demand recognition!"
Intel or AMD - Just depends on what you're doing
speedytech7 is offline
post #5 of 6 Old 08-06-2013, 11:09 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 0
There are no extra standoffs.
And no, it has yet to boot in the new case. I had my build working in my old case before the old case broke.
post #6 of 6 Old 08-07-2013, 09:37 AM
Overclocker in Training
Quoted: 0 Post(s)
Liked: 25
Had this problem, ended up cutting little squares of electricians tape, placing them between the standoffs /MB and poked a hole through them with an ice pick, then used fiber washers on the screw side. The proper size nylon washers should be available at a well stocked hardware store.
Aleslammer is offline
