Dremel For Cutting Case - Overclock.net
post #1 of 5 Old 01-01-2006, 09:13 PM - Thread Starter
4.0ghz
not2bad's Avatar
Quoted: 0 Post(s)
Liked: 175
Is this good for basic modding? Like cutting a fan hole or something..
http://www.dremel.com/HTML/home_fr.html
EDIT: Click "Cordless Rotary Tools And Kits" in the middle and then "#7700-02 7.2V Cordless MultiPro® Rotary Tool Kit".
Spiritt likes this.
Chimp Challenge 3 x Participant  2 Million+ Folding at Home points
not2bad is offline
post #2 of 5 Old 01-01-2006, 09:16 PM
Freeze It
MADMAX22's Avatar
Quoted: 0 Post(s)
Liked: 582
over all for general modding thats great (dont get the rechargable ones) but for cuting fan holes go to like homedepot or a hardware store and get one of those drill bits that have the drill in the center for lining it up and the big round circular cutter that goes around the outside
they will cut a perfect circle and you can get them in the sizes that you need
not2bad likes this.
E6400@3856E4300@4158E6600@4510,Opti148@3102,opti170@2918,UD3P&9550@4692
UD3P&84005304,UD3p&85005567
4 Million+ Folding at Home points
MADMAX22 is offline
post #3 of 5 Old 01-01-2006, 09:20 PM - Thread Starter
4.0ghz
not2bad's Avatar
Quoted: 0 Post(s)
Liked: 175
So for cutting windows and stuff they good? Walmart sells the 7.2V one for 30 bucks so I'm planning on getting one.
not2bad is offline
post #4 of 5 Old 01-01-2006, 09:26 PM
Freeze It
MADMAX22's Avatar
Quoted: 0 Post(s)
Liked: 582
yeah they are good for alot of stuff but for doing like the inside cuts make sure you get the little router type attachment that allows you to go around the inside of say plexiglass or plastic or something
im just saying that for something like fan holes where you want a nice cirlce you would need to use a regular drill with one of those bit im talking about
i added a pic of one
MADMAX22 is offline
post #5 of 5 Old 01-01-2006, 10:09 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 132
Yes,for perfect circles,use a hole cutting bit for a drill. They are quick,simple,and cheap. For cutting simple windows i reccomend a jigsaw over a dremel anyday,but for the more intricate windows,a dremel is the only option.
Definitely dont go cordless though,its too much of a hassle,the battery will likely die within minutes grinding through hardened steel. Ive had my corded one for 5 years now and its still going strong.
TylerBello is offline
