Must Read!!!!!! - Page 2 - Overclock.net
post #11 of 27 Old 11-30-2006, 03:19 PM
TheEddie's Avatar
Quoted: 0 Post(s)
Liked: 137
Originally Posted by hvacgaspiping View Post
Actually, aluminum is a slightly better conductor of heat than copper. Maybe you could do something similar with a soft drink can and have more surface area to transfer heat. Plus, it would be thinner and have greater ability to remove heat.
I really dont think aluminum is a better conductor of heat than copper..
TheEddie is offline
post #12 of 27 Old 11-30-2006, 03:23 PM
4.0ghz
mashersmasher's Avatar
Quoted: 0 Post(s)
Liked: 156
Originally Posted by Kopi View Post
yep. Copper is better conductor or heat/electricity aswell. 's why its used in things like wires for electronics and heatsinks for computers. Aluminum is used aswell, but its cheaper i think
that's why most of the big transformers you see at your local power station use copper windings. to prevent them from burning out in the summer. or so i have heard. it's also cheap. but as for the coins i was thinking. if you have any Mexican coins (the really thick ones), i think their made of bronze which contains copper and i imagine that it's size would make it potentially a better for cooling than regular penny's. and i also saw these 2 pence British coins in my change bin that were about twice the size of a penny but those are worth about 5 cents each.
edit: i think that the coins are Cuban not Mexican
i want to crush you all in a colossal robot
mashersmasher might!
but before that. if you need to oc a 478 cpu on a crappy mobo click here
and if you need gas masks look here
and if you need a place to hide something here
BUY MY STUFF!!!
you know you want to!
mashersmasher is offline
post #13 of 27 Old 11-30-2006, 03:23 PM
3.5ghz
hvacgaspiping's Avatar
Quoted: 0 Post(s)
Liked: 71
I remember way back in the 70`s that air conditioning manufacturers started using aluminum condenser and evaporator coils not only because aluminum was cheaper, but it transferred heat faster. The reason they went back to copper was that it was extremely difficult to fix a leak on aluminum in those applications, because the refrigerant oil that was present inside the tubes made it all but impossible to effectively solder a leak. Had that not been an issue, I believe that aluminum would still be used today in those applications.
cheers.gif Proud member of Team Folders, Inc.
hvacgaspiping is offline
post #14 of 27 Old 11-30-2006, 03:25 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
EDIT: Never mind...Sorry.....
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #15 of 27 Old 11-30-2006, 09:55 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 156
in the 70'a there was a copper shortage. i know copper is a better heat conductor though it is possible that they used aluminum as a replacement as it is somewhat effective. aluminum was used to replace allot of things that copper was used for like wires for homes, transformers (which sorta stuck) and even motors. as for soldering it is possible to solder Aluminum. in fact the only thing i haven't been able to solder is zink
BUY MY STUFF!!!
post #16 of 27 Old 11-30-2006, 09:57 PM
Bifford
BFRD's Avatar
Quoted: 0 Post(s)
Liked: 264
Just FYI pennies have almost no copper in them they are mostly zinc.
EDIT: Ironically the nickel is mostly copper.
BFRD is offline
post #17 of 27 Old 11-30-2006, 10:11 PM
..the party can start now
Quoted: 0 Post(s)
Liked: 589
well...while your story is probably true, it's more likely the fact they were short on copper.
Copper conducts heat better than aluminum. It's a fact.
Sideburns is offline
post #18 of 27 Old 11-30-2006, 10:58 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 156
this is true. you have to look for 1970's and older to get copper ones. as for the nickels is that true? maybe worth a check. and are those American nickels?
BUY MY STUFF!!!
post #19 of 27 Old 11-30-2006, 11:55 PM
733mhz
Quoted: 0 Post(s)
Liked: 4
wow so the nickel version would be the 5 cent upgrade? is there a way to melt the nickels together and what is the best glue to use? I have rubber cement, super glue, a hot glue gun and wood glue.
metalmodman is offline
post #20 of 27 Old 11-30-2006, 11:59 PM
Semi-Retired OCer
PROBN4LYFE's Avatar
Quoted: 0 Post(s)
Liked: 603
That's why he says pennies before 1982...I got some '75s!!!
That is so sweet...
PROBN4LYFE is offline
