Overvolting, and my next BT experiment - Overclock.net
post #1 of 5 Old 04-03-2006, 11:27 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 190
Alrigth...i know how o overvolt, i just screwed up and severed all the atx leads on my test PSUs, so i can't turn them into fan workhorses. Question one: Is there a way to overvolt without sacrificing my psu.
Question two...
Has anyone trid using evaporative air cooling on a CPU to reduce temps below ambiant? I plan on doing just that...and i will chronicle my trials and travails in this forum.. Once it is done, i plan to write a guide on it and spread the wealth. I plan on using ahumidifier to pump light moisture into ducting leading to the BT, and using plexi and neoprene to seal the apparatus from any electronic componants. Also ducting the humdid air out of the computer into a dehumidifier, which will drain into the humidifier resovoir (that last part is a little ways down the road, as i do not have access to a dehumidifier as of yet) I'm hoping to do this as cleanly as possible, without the udly mess.
Thank goodness i have my brothers computer lying around, or i wouldn;t be able to bring this modding goodness to you.
Check out how to mod your BT or see if your Sapphire X800GTO² can be unlocked. in my FAQs
also, i am using a Coolermaster 690 with stock fans, which i hear blow goats. Dunno though.
3DMark06: 14637 proof.gif
HardwaterH4ck3r is offline
post #2 of 5 Old 04-03-2006, 03:13 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 190
bump
post #3 of 5 Old 04-06-2006, 10:13 AM
krunks bad at pc's
bigvaL's Avatar
Quoted: 0 Post(s)
Liked: 898
Doesnt sound worth it. You're cooling the big typhoon with the moisture? A waterblock will easily outperform that, if that is the case. Also, what are you trying to overvolt? The 12V rail?
FOLD FOR OCN - TEAM 37726
OC Settings: 4800mhz 100x48, 1.4500 vcore, 1600mhz Mem 9-9-9-24, 1200/1600 GPU @ 1.26v.
bigvaL is offline
post #4 of 5 Old 04-08-2006, 08:27 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 190
It's easy to overvolt....i just ddin;t want to kill my current psu.....
Anyway...i am moving on to another experiment...this involving an evaporator, glycol, and a copper pipe.....
post #5 of 5 Old 04-12-2006, 06:59 PM
noxious89123's Avatar
Quoted: 0 Post(s)
Liked: 135
Keep away from naked flames, lol. Glycol sounds flamable.
Dont think that idea would work :/
noxious89123 is offline
