Danger Den Monsoon D5 Dual-Bay Reservoir w/ Pump - Overclock.net
post #1 of 2 Old 04-19-2014, 10:32 AM - Thread Starter
Back on the Air
losttsol's Avatar
Quoted: 0 Post(s)
Liked: 607
Here is a link to the product, except mine is an all black version with chrome (badass looking), with a black brushed aluminum faceplate. There is a pump pre-installed in the unit. You can basically just put it right into your loop provided you have two hose barbs (not included). The pump is a non-vario Laing D5 pump. The reservoir is only a couple years old and hasn't been used for about 6 months. The pump though is about 6 years old. The pump worked fine still when I took the reservoir out of my rig, but I am not warrantying the pump in any way because of its age. This reservoir has a UV light that must be turned on manually with the buttons on the front. There is a silver kill coil in the reservoir as well that I didn't take out. If you don't want it, you can easily remove it. I didn't have a problem with it being in there, you just have to be careful it doesn't interfere with the pump. Some people don't like them in there for that reason, your choice. Although it has UV lights, I only ran distilled water through the unit. I've included some pictures of what it looks like lit up in my old rig. Being I only ran water, the UV isn't too bright, but still looks good. UV liquid would look better though. This is a very nice piece of water cooling gear and it needs a good home.
What's included:
Danger Den D5 Monsoon Dual Bay Reservoir
UV Light (pre-installed)
D5 Pump (pre-installed)
Danger Den Sticker
Instruction Booklet
A few odd bolts and gaskets you might want, but you don't necessarily need them.
What's not included:
Hose barbs or any other fittings, except the plugs in the other ports.
Any question you may have please feel free to ask.
$100 Shipped or...
Will trade for a 256GB SATA 6Gb/s SSD in good condition/fairly low hours
-sorry, but I don't really need anything else.
losttsol is offline
post #2 of 2 Old 04-25-2014, 07:56 PM
Folding Fanatic
LarsL's Avatar
Quoted: 0 Post(s)
Liked: 23
LarsL is offline
