EK introduces new REVO D5 series of pumps and reservoirs combos - Page 7 - Overclock.net
post #61 of 369 Old 10-02-2015, 01:17 AM
AidenH96's Avatar
Quoted: 0 Post(s)
Liked: 1
Originally Posted by Bear304 View Post
Indeed. thumb.gif Thanks for the info.
AidenH96 is offline
post #62 of 369 Old 10-03-2015, 11:28 PM
please keep drinking the koolaide
Mega Man's Avatar
Quoted: 0 Post(s)
Liked: 700
@EK_tiborrr @akira749
do you need the diva mod to make this work with aquaero !
Originally Posted by IT Diva View Post
Yes, . . . .
There's a really good way with an add-on PCB, but there's also a quick and easy way that yields acceptable results without having to run wires and plug into a 5V molex pin somewhere.
Here's copied from the "old" A6 thread with some additional information:
For the capable DIY'er . . .
While not as optimal a solution as the active component based solutions, this is a workable solution to the issue of having a PWM D5.
I've tried it on a single and a dual D5 setup and it works satisfactorily with pullups optimized for each case, and it's dead nuts simple, though not exactly elegant.
At issue is that the D5 needs a fairly "strong" pullup, (lower resistance) . . . while the A6 works best with weaker pullups, (higher resistance).
This setup uses the 12V available from the first 2 of the 4 PWM fan pins on each channel of the A6.
The Zener diode and larger resistor form a 5V regulated source that the smaller resistor connects the PWM line to.
The diode is a 5.1V Zener diode, and the larger resistor, the 1/2 W one, is a 560 Ohm, but 470, 680, 820, or 1K will work as well. 1K may be the easiest to find.
Be sure you have the Zener diode polarity connected as in the pic.
The smaller resistor, 1/4 W, is a 2.2K which I'd suggest for a dual D5 setup, but for a single D5, a 3.3K would be fine.
The smaller size, 1/6W or 1/8W are electrically OK, but the smaller physical size makes lead breakage more of an issue, so stay with 1/4W.
Everything shown is available from RadioShack.
Hope that helps,
Darlene
IE does this have the pullup for the pwm line ?
Rigbuilder and how to put it in your sig post-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gifpost-flame-small.gif budget components = budget resultsPearls before swine! (Click to show)
Also rma wise, regardless of what vendor used it's always like getting a tooth pulled imo.
I facepalmed when trying to explain cpu and gpu overclocking to him after he got his 4930k. It was like teaching trigonometry to a rock.
That's like wrapping your car around a pole then asking for warranty service.
Dont be hard on yourself, we all break stuff sooner or later.
I don't appreciate your judgment here. I am just stating facts. That's all I'm doing. If you are taking offense to it or something, then that's not my problem, so don't put it on me. Ok?...Good god man. You would know that if you would actually carefully read...
Mega Man is offline
post #63 of 369 Old 10-04-2015, 07:14 AM - Thread Starter
EKWB Forum Support Representative
Quoted: 0 Post(s)
Liked: 279
I will let the Chief (@EK_tiborrr) answer this one but since it's not a "special" D5 PWM that we sell, I would say yes.
akira749 is offline
post #64 of 369 Old 10-07-2015, 12:53 PM
WaterCooler
Rahldrac's Avatar
Quoted: 0 Post(s)
Liked: 11
Are you going to release a Vario version of the D5 Revo? Any specific reasons for not going with the "set and forget" way with this pump? smile.gif
Rahldrac is offline
post #65 of 369 Old 10-08-2015, 05:11 AM
MORE THAN LIFE
tiborrr12's Avatar
Quoted: 0 Post(s)
Liked: 156
Not likely. We are steering away from non-PWM controlled gear in our portfolio. However you can still assemble your own D5 Revo with Vario pump smile.gif
EK R&D Chief
ekwb.com
Follow us on Facebook & twitter!
Please do not message me on PM.
tiborrr12 is offline
post #66 of 369 Old 10-08-2015, 06:59 AM
WaterCooler
Rahldrac's Avatar
Quoted: 0 Post(s)
Liked: 11
Is the d5 pwm problem just with aquaero, or is it with normal motherboards too?
Rahldrac is offline
post #67 of 369 Old 10-08-2015, 07:03 AM
Mega Man's Avatar
Quoted: 0 Post(s)
Liked: 700
it isnt a problem with the aquaero. it is a problem with the implementation of the pwm on the d5s ( Lang did not follow pwm spec ( from intel ) and did not include a pullup circuit ) that said most mobos dont seem to care but some might/do
Mega Man is offline
post #68 of 369 Old 10-08-2015, 07:25 AM
WaterCooler
Just a nickname's Avatar
Quoted: 0 Post(s)
Liked: 170
Wow... I need this!
CPU owned:
i5-750 & EVGA Classified 200 - 4.8GHz
i7-870 & EVGA Classified 200 - 5GHz
i7-2600k & Z77X-UD3H - 5GHz
i7-4790k & MSI Gaming 5 - 5GHz
Just a nickname is offline
post #69 of 369 Old 10-11-2015, 07:03 AM
barsh90's Avatar
Quoted: 0 Post(s)
Liked: 20
Which one is quieter? the old square one or the revo? Planning on replacing my current xspc combo. At speed 3.5-5 is quiet but I can hear a high pitched noise that drives me nuts.
barsh90 is offline
post #70 of 369 Old 10-11-2015, 07:42 AM
MORE THAN LIFE
tiborrr12's Avatar
Quoted: 0 Post(s)
Liked: 156
Both are more or less the same, new one should be more quiet tbh.
EK R&D Chief
ekwb.com
