CPU overheating on 600mm rad - Overclock.net
post #1 of 18 Old 07-19-2016, 11:16 AM - Thread Starter
simon771's Avatar
Quoted: 0 Post(s)
Liked: 0
So I'm using i7 4790K and my temps get to 80-90°C when stress testing.
240mm + 360mm rad
All fans to 100%
Airflow is decent and I can feel air going trough radiators.
Changed thermal paste few times already and still same result.
I just don't know what I did wrong and why is it overhating.
Any suggestions?
simon771 is offline
post #2 of 18 Old 07-19-2016, 11:18 AM
killerhz's Avatar
Quoted: 5 Post(s)
Liked: 416
you have made sure your voltages are good? took them off default setting s?
killerhz is online now
post #3 of 18 Old 07-19-2016, 11:32 AM
WaterCooler
kl6mk6's Avatar
Quoted: 0 Post(s)
Liked: 154
^^^ this, auto bios settings can overvolt your cpu using some stress tests, especially ones that run AVX. For the 4970k you can set your voltage manually to 1.250V at 46x core multiplier and set your uncore (cache) to 40x at 1.2v and see how it runs under stress. if it fails drop your multiplier to 45x. Check out the The Intel Devil's Canyon Owners Club[/B and the Skylake Overclocking Guide [With Statistics] for more information
If you are still having issues you may need to remount your cpu block, verify your water flow, or potentially delid the cpu (helped for about 10C drop in temps under load on my 4790k)
kl6mk6 is offline
post #4 of 18 Old 07-19-2016, 11:37 AM
Duality92's Avatar
Quoted: 0 Post(s)
Liked: 176
We need more info.
Let us know what settings you're running your CPU at. Is it delidded? what CPU block are you using? What pump?
Show us a picture, it'll help us all help you!
Duality92 is online now
post #5 of 18 Old 07-19-2016, 12:10 PM
Quoted: 0 Post(s)
Liked: 101
If you have horizontally mounted radiators they may very well have air bubbles in them and need bleeding.
essanbee is online now
post #6 of 18 Old 07-19-2016, 12:22 PM - Thread Starter
simon771's Avatar
Quoted: 0 Post(s)
Liked: 0
Okay guys, after more research, I think I found the problem ...
I need "shim" or something like that.
I did put thermal paste on my CPU and spreaded it around so it was very thin. Then I put on waterblock and removed it .... not a single mark of thermal paste on waterblock.
So I guess it was kinda okay till now because I had more thermal paste on it, but in the end, waterblock isn't touching CPU directly.
I did put CPU out of the socket and pressed it against waterblock gently. Waterblock was full of thermal paste.
So all I need to do now, is to buy copper shim.
simon771 is offline
post #7 of 18 Old 07-19-2016, 12:31 PM
Quoted: 0 Post(s)
Liked: 101
Ah it was an air bubble, just not where I thought. Best of luck with the shim.
post #8 of 18 Old 07-19-2016, 12:43 PM
Overclocker
BURGER4life's Avatar
Quoted: 0 Post(s)
Liked: 37
Normally you don't need to shim your CPU... What waterblock do you use? Is it mounted correctly?
BURGER4life is offline
post #9 of 18 Old 07-19-2016, 03:21 PM - Thread Starter
simon771's Avatar
Quoted: 0 Post(s)
Liked: 0
I'm using EK Supremacy EVO Nickel Plexi.
I think my CPU socket on motherboard could be bent a bit and causing this. It hold CPU in place with no problems, but I don't see anything else that could be blocking waterblock from directly touching my CPU.
I will try that https://www.ekwb.com/shop/ek-vga-supreme-hf-hd7970-cu-adapter
Worst case I spend 3€ on it, an try to find another solution.
I hope xD
simon771 is offline
post #10 of 18 Old 07-19-2016, 03:44 PM
WaterCooler
kl6mk6's Avatar
Quoted: 0 Post(s)
Liked: 154
You should definitely talk to a rep before you buy anything, the kits should work out of the box just fine. Try asking in the EK Club. they have service reps that monitor the forum and have other people that can probably give you sound advice. thumb.gif
kl6mk6 is offline
