EK Mono Block for Maximus X Apex - Page 3 - Overclock.net
post #21 of 32 Old 12-02-2017, 09:08 PM - Thread Starter
rjb64's Avatar
Quoted: 0 Post(s)
Liked: 1
Still nothing official from EK?
CPU: I7 3930K @ 4.85 Ghz w EK Supremacy
Mobo: ASUS RIVE w 16GB Dominator 1880 9-10-9-27 2T
GPU's: 2 GTX 780Ti 3 GB SLi w EK Full WB's
Drives: SSD - 1 Intel 120 GB - 1 x Vertex II 240 GB (OS n Games) / 2 x WD Black 640GB (Data)
PSU: AX 1.2 kW
Case n Cooling: Corsair 900D w Lamptron FC9 Controller x 2 XSPC EX 360's & Photon 170 Combo - Dell U2711 2560x1440
MK11: P25,113
http://www.3dmark.com/3dm11/7499603
Firestrike: 19,576
http://www.3dmark.com/fs/1177627
rjb64 is offline
post #22 of 32 Old 12-13-2017, 11:52 AM
Batman1982's Avatar
Quoted: 0 Post(s)
Liked: 2
Ok, build my new rig yesterday with the apex.
Monoblock from the apex9 didn‘t fit in all holes. One on the right side is the Problem.
I mounted it without the screw. You need thicker thermalpads on the vrms itself i‘ve used 1,5mm. On the conductors is 1 mm ok
So now the sytem works and under linx 5ghz vrm are 44degrees.
Seems to work fine. But gave no warrenty that it works on every apex.
Batman1982 is offline
post #23 of 32 Old 12-13-2017, 11:55 AM
Batman1982's Avatar
Quoted: 0 Post(s)
Liked: 2
post #24 of 32 Old 12-13-2017, 12:08 PM
Quoted: 0 Post(s)
Liked: 197
I'm confused. There's an official monoblock for the Apex on Ek's website. I bought mine 2 weeks ago.
startekee is offline
post #25 of 32 Old 12-13-2017, 12:12 PM
Batman1982's Avatar
Quoted: 0 Post(s)
Liked: 2
Hm very strange, i got mine yesterday and saw that the hole in the right corner didn‘t fix,
Maybe it was a old block and they change it.
post #26 of 32 Old 12-13-2017, 12:25 PM
MNMadman's Avatar
Quoted: 0 Post(s)
Liked: 49
Yes, their configurator does have the M9A monoblock for the M10A.
I don't like that the one screw won't fit, and the thermal pads are wrong. I will look into the separate VRM block from WaterCool if I go with the Apex board for my new build.
BOINC Pentathlon Participant
MNMadman is offline
post #27 of 32 Old 12-13-2017, 12:31 PM
Commodore 64
Quoted: 0 Post(s)
Liked: 2
I just looked at the EK web store, and they have no monoblocks for Z370 boards......you are definitely confused smile.gif
EDIT: I didn't use the configurator, so I didn't know the site was "suggesting" the block would work. I just know there's no official block for any Z370 board atm.
Thrakazog is offline
post #28 of 32 Old 12-13-2017, 12:34 PM
Quoted: 0 Post(s)
Liked: 197
I definitely was. I was thinking you guys were talking about the X299 Apex
post #29 of 32 Old 12-15-2017, 09:15 PM - Thread Starter
rjb64's Avatar
Quoted: 0 Post(s)
Liked: 1
Real disappointment that EK didnt step up here. I mean the 8700K is huge oc'ing monster and paired the Apex Board ?
PSU: AX 1.2 kW
MK11: P25,113
Firestrike: 19,576
rjb64 is offline
post #30 of 32 Old 12-16-2017, 03:29 AM
Commodore 64
Quoted: 0 Post(s)
Liked: 2
From what I've seen of video reviews, the VRM's stay incredibly cool on the APEX board anyways, so I'm just going to use a sup/evo cpu block when I build with it.
