Need: Cpu & Motherboard. <$180 To Spend. Please Suggest Options. - Page 2 - Overclock.net
post #11 of 31 Old 03-06-2013, 10:41 PM
Stay Puft's Avatar
Quoted: 0 Post(s)
Liked: 291
Originally Posted by drnilly007 View Post
Usually have crap components
It's a 3220/B75 combo. Not crap at all.
Stay Puft is offline
post #12 of 31 Old 03-06-2013, 11:08 PM
Overclocker
DaFirnz's Avatar
Quoted: 0 Post(s)
Liked: 66
That actually looks like a pretty good deal.
Pros 4x usb 3.0 on the back panel
mobo has 3 year warranty
cons no usb 3.0 internal header
only 1 sata 6gb/s port
DaFirnz is offline
post #13 of 31 Old 03-07-2013, 11:24 AM
AlphaC's Avatar
Quoted: 1 Post(s)
Liked: 805
^ Cons: It's AsRock which is known to have analog mosfets on lga1155 :S
Validation (Click to show)
4.49GHz @1.272-1.284V , 11hr Prime95
-> original
gimped BCLK (125W TDP limit)
4.6GHz@1.272-1.284V (Overvolt enabled), 14hr Prime95
4.7GHz @1.296-1.32V (Overvolt enabled), 14hr OCCT Linpack (& F19e BIOS , OCCT 11hr)
4.8GHz @1.296V
5.1Ghz @1.404V (130W TDP) .... wish it was stable
Sandy Bridge Binning guide @ HWBot
AMD Ryzen 7 1700X @ 3.925GHz 1.35V dynamic voltage ... 1hr AIDA64 (8hr AVX Prime95 with -50MHz)
W.I.P R7 1700X @ 4.040GHz (Fixed voltage is bugged , this booted at 1.39V , testing in Windows 10 PE so no GPU driver)
40.75 multi @ 1.39V
41 multi, booted @ ~ 1.41V
Recommended GPU Projects: Einstein@Home , Milkyway@Home (Tahiti , Cayman , Cypress Radeons) (AMD moreso)
Other notable GPU projects: Asteroids@Home (nvidia), GPUGrid (nvidia) , Universe@Home (Tahiti , Cayman , Cypress Radeons with double precision) (AMD)
Project list
AlphaC is offline
post #14 of 31 Old 03-07-2013, 11:58 AM
Stay Puft's Avatar
Quoted: 0 Post(s)
Liked: 291
I'm so sick of hearing about this. Sin benched an Extreme4 and it did 5.3Ghz and didnt blow up on a test bench. What makes you think you'll have a problem in a case with airflow running ove rthe motherboard?
I myself ran a 3770K at 4.8Ghz on a Z77 Pro3 for 6 months and it had no issues. I wouldnt post the combo if i didnt have faith in it.
post #15 of 31 Old 03-07-2013, 08:48 PM - Thread Starter
PC Gamer
Offender_Mullet's Avatar
Quoted: 0 Post(s)
Liked: 67
Thank you for your recommendations and provided links guys. thumb.gif I'll give it another week before I purchase anything, then let you know what I come up with. smile.gif
Offender_Mullet is offline
post #16 of 31 Old 03-10-2013, 06:00 PM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 67
Alrighty, after searching non-stop the past few days and going through waaaaay tooooo much Copenhagen while doing so tongue.gifbiggrin.gif I've boiled it down to these 3 options. I already know what most of you will say smile.gif but I'm just throwing the AMD ones out there.
AMD #1 the "oldschool cpu" build
Cpu: http://www.microcenter.com/product/325874/Phenom_II_X4_965_Black_Edition_34GHz_Boxed_Processor (the Phenom II X6 1045T is also the same price)
Motherboard: http://www.microcenter.com/product/375772/GA-970A-UD3_Socket_AM3_970_ATX_AMD_Motherboard (open box)
Total: $172.35
AMD #2
Cpu: http://www.microcenter.com/product/401797/FX_6300_Black_Edition_35GHz_Six-Core_Socket_AM3_Boxed_Processor
Motherboard: http://www.microcenter.com/product/382894/970_Extreme3_Socket_AM3_970_ATX_AMD_Motherboard
Total: $177.77
INTEL
Cpu: http://www.microcenter.com/product/398006/Core_i3_3225_33GHz_LGA_1155_Boxed_Processor
Motherboard: http://www.microcenter.com/product/398418/GA-B75M-D3H_LGA_1155_mATX_Intel_Motherboard
Total: $172.38
The FX-6300 and i3-3225 both have their advantages and disadvantages, but part of me wants to try the FX-6300. Not really sure what to do. I forgot I had a 4GB of Kingston HyperX T1 2000MHz ram, so now I don't have to buy any. thumb.gif This is only a temp build anyway. Once I get the upgrade bug late this year or early next, then I'll go over to Haswell.
post #17 of 31 Old 03-10-2013, 08:37 PM
AlphaC's Avatar
Quoted: 1 Post(s)
Liked: 805
May want to grab the AM3+ stuff (FX-6300) for resale value.... i3 will be basically unsellable , both CPU and motherboard will be old stuff
& you could overclock it.
Just my thought on that
-> original
4.8GHz @1.296V
40.75 multi @ 1.39V
Project list
AlphaC is offline
post #18 of 31 Old 03-10-2013, 08:45 PM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 67
That's what I was thinking as well. Thanks for all the info you posted in here Alpha.
post #19 of 31 Old 03-11-2013, 01:58 AM
Overclocker
DaFirnz's Avatar
Quoted: 0 Post(s)
Liked: 66
Does the AMD board support the fx-8350? If it does and you felt the need to upgrade, bam, i5 killer. Or at least same as. If not still might be the best option.
DaFirnz is offline
post #20 of 31 Old 03-11-2013, 03:52 AM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 67
Yes, all 3 that I listed support the 8350. However, I'm going to ditch the ASRock and get the Gigabyte GA-970A-UD3 instead. It seems to have a much more 'robust' power phase compared to the ASRock. I didn't want to fall into the "it doesn't cost that much more" trap, which can snowball depending on how many components you're buying, but I really didn't want to skimp on the motherboard. Plus, I've never been crazy about ASRock boards.
