molex to sata power problem - Overclock.net
post #1 of 8 Old 07-27-2013, 10:58 AM - Thread Starter
Scott1541's Avatar
Quoted: 1 Post(s)
Liked: 65
I'm not going to explain the story behind this but basically I've bodged together a sata power connector and a female molex connector from one of those molex to PCI-E adapters. The sata power connector only has 5 wires going in, yellow, red, 2 black and orange. I read in another thread on here that you can ignore the orange wire and just hook these coloured wires up the the same coloured wires of the molex connector.
So I did that and then went to test my new contraption. When testing it the hard drive will power up and begin to load windows, then it seems like the computer is reset and boots again to the screen where you have the option to boot normally or launch the repair utility. After selecting boot normally the same thing happens again.
So far I've checked the connections with a multimeter and they were alright, I don't know what to do now though, any help?
The PSU is just an old OEM one, 250W with only molex and floppy connectors, hence why I'm doing this tongue.gif The HDD is a 2.5" hitachi drive, which was working fine about 2 weeks ago, but I haven't checked since.
Camera Gear: Nikon D600, D7200, F60 & much more...
Steam: scott1541
Origin: Scott3933OCN Funnies... (Click to show)
"yawn. RMS is trolling again. Wake me when he returns to planet Earth"
"Staying inside doesn't get you mounting your telephoto on some F mount."
Scott1541 is offline
post #2 of 8 Old 07-27-2013, 11:06 AM
Case Modder
evil_scotsman's Avatar
Quoted: 0 Post(s)
Liked: 9
Not that I'm any kind of expert, but maybe the first port of call would be to try the HDD without the adapter? Just to immediately take the HDD being the problem out of the equation and to prevent this being suggested down the line.
Clubs & Builds (Click to show)Tomfoolery (Click to show)
Originally posted by andrews2547
Just bought a MacBook Pro? I feel bad for you son...
Originally posted by [Adz] in reply to ^
I got ninety-nine computers but a Mac ain't one
Originally posted by Hamy144
I absolutely adore the defender. So bummed my dad pulled out of buying one at the last minute or I would have it as my first cat
Originally posted by evil_scotsman in reply to ^
Sir, you sicken me. Using a cat as means of transportation.
Steam: evil_scotsman56 (profile name: paulosaurus)
Origin: paulosaurus90
evil_scotsman is offline
post #3 of 8 Old 07-27-2013, 11:16 AM - Thread Starter
Scott1541's Avatar
Quoted: 1 Post(s)
Liked: 65
Just tried to boot the same computer but using an externally powered USB caddy. It happened again so I guess it's the hard drive frown.gif As I mentioned in the OP it was working fine a few weeks ago.... Hitachi piece of crap mad.gif
Edit: It seems to be working alright when connected to my rig, I'm not booting from it but I can access all of the files fine.
Steam: scott1541
post #4 of 8 Old 07-27-2013, 12:31 PM
If it ain't broke, make it faster
PedroC1999's Avatar
Quoted: 0 Post(s)
Liked: 313
Try rebuilding the MBR, may solve that
Scott1541 likes this.
PedroC1999 is offline
post #5 of 8 Old 07-28-2013, 04:23 AM - Thread Starter
Scott1541's Avatar
Quoted: 1 Post(s)
Liked: 65
THis morning I hooked it back up to my rig again, formatted it then did a bit of testing and benchmarking on it. Crystaldiskmark didn't show any problems and the benchmarks looked good so I put it back in the other rig and began installing windows 7.
Everything seems to be working alright and the installation is going good thumb.gif (touch wood)
Steam: scott1541
post #6 of 8 Old 07-28-2013, 04:25 AM
PedroC1999's Avatar
Quoted: 0 Post(s)
Liked: 313
Re-Installing windows does rebuild the MBR, so that will probably solve your issue, anyways, best of luck Scott smile.gifthumb.gif
post #7 of 8 Old 07-28-2013, 04:29 AM - Thread Starter
Scott1541's Avatar
Quoted: 1 Post(s)
Liked: 65
I was going to reinstall anyway so I didn't want to bother manually rebuilding the MBR. Thanks for your input Pedro smile.gif
Steam: scott1541
post #8 of 8 Old 07-28-2013, 04:34 AM
PedroC1999's Avatar
Quoted: 0 Post(s)
Liked: 313
