Soldering Question - Overclock.net
post #1 of 10 Old 02-18-2009, 12:15 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 24
Sorry for being a noob but still learning as I go.
Does it matter what type of solder I use for volt mod or any computer component related soldering? Can I just pick up a cheap solder in my local hardware store? Thanks
"A cache is not a pipe. A cache is a pool, so the question becomes - what's faster, a 3x3 pool, or a 4x4 pool?"
"Arguing with an moderator is like wrestling with a pig in mud.....after a while you realize the pig enjoys it!"
"What achieved success was the very chaos that the Internet is. The strength of the Internet is that chaos."
Manji is offline
post #2 of 10 Old 02-18-2009, 12:23 AM
SR-2 can do 5 GiggleHertz
H3||scr3am's Avatar
Quoted: 0 Post(s)
Liked: 315
generally anything will do jsut fine... I go with the thinner, with 4% silver content and Aggressive rosin flux... for better flow... but thats just personal preference... and I do a lot of audio mods as well...
radio shack rosin core solder will do the job...
CISSP, ITIL v3 Foundations, Security+, Linux+, Cloud+, Server+, Project+, Network+, A+, LPIC-1
Working on: CCENT
H3||scr3am is offline
post #3 of 10 Old 02-18-2009, 06:43 PM
4.0ghz
RADEON's Avatar
Quoted: 0 Post(s)
Liked: 66
Make sure it has rosin flux and not acid flux (used for soldering copper pipes and such), or it will corrode.
The War Continues...
AMD gunner2.gifgunner.gif intel
RADEON is offline
post #4 of 10 Old 02-18-2009, 06:47 PM
4.0ghz
samfreese's Avatar
Quoted: 0 Post(s)
Liked: 91
Silver solder is better, but for what you're doing pretty much anything will work. And like radeon said, no acid flux.
--Saint Louis Overclockers--
samfreese is offline
post #5 of 10 Old 02-18-2009, 08:56 PM
333mhz
LTCoogan's Avatar
Quoted: 0 Post(s)
Liked: 1
for electronics you want your soldering iron at 750 degrees celcius and solder thats 40% tin 50% copper with a rosin core is wat i used in my computer building
CL3P20 likes this.
LTCoogan is offline
post #6 of 10 Old 10-09-2009, 08:10 PM
AMD Overclocker
SwishaMane's Avatar
Quoted: 0 Post(s)
Liked: 106
15watt iron for electronics... anything higher is for other applications. And no soldering guns, those are garbage for small electronics work.
Personal best - 11,811 in 3DMark06 on 01/16/2016 socket 939 baby!
Proud elite member of the Socket 939 Appreciation Club.
SwishaMane is offline
post #7 of 10 Old 10-13-2009, 06:26 PM
CL3P20's Avatar
Quoted: 0 Post(s)
Liked: 1056
QFT
CL3P20 is offline
post #8 of 10 Old 10-22-2009, 12:31 AM
WaterCooler
ian209's Avatar
Quoted: 0 Post(s)
Liked: 53
Well for SMT/SMD, it's 600-650*F, but that's what i learned :/
Dude U.S. Army is like Halo except there are no re-spawns.
ian209 is offline
post #9 of 10 Old 10-22-2009, 12:39 AM
4.0ghz
Ktmrida4life's Avatar
Quoted: 0 Post(s)
Liked: 64
Yes, thats right. Not sure what the dude a couple posts up is talking about with 750*C, that will lift a trace/pad off a board because its wayyyyyy too much heat. Solder usually melts around the 180-250*C range, which is like 400*F or something.
To the OP, go to radioshack and get either the adjustable wattage soldering iron.. should see it. Its pretty small and the switch will let you select between 15W and 30W. Also get some thin silver bearing solder, as it works pretty good.
Awesome. Never piss off 4chan, nobody can defeat an army of pissed off nerds.
Ktmrida4life is offline
post #10 of 10 Old 10-25-2009, 07:06 AM
Commodore 64
ShadowReaper's Avatar
Quoted: 0 Post(s)
Liked: 0
ShadowReaper is offline
