1 powerful card or 2 in sli/crossfire? - Page 3 - Overclock.net
post #21 of 51 Old 10-18-2011, 10:30 PM
kremtok's Avatar
Quoted: 0 Post(s)
Liked: 370
Originally Posted by sharkattack99 View Post
and what do you single card people recommend for a high end single GPU?
I wouldn't spend my money on anything greater than a GTX 570 or the AMD equivalent.
Reason. Purpose. Self Esteem.
My Little Pony: Overclocking is Magic!
XBox Live Gamertag: Kremtok
Chimp Challenge Participant  Foldathon Folder - 2013 Participant  250 Million Folding Points  Foldathon Participant 2015  Foldathon Participant 2017  Forum Folding War 2017
kremtok is offline
post #22 of 51 Old 10-18-2011, 10:42 PM - Thread Starter
733mhz
sharkattack99's Avatar
Quoted: 0 Post(s)
Liked: 0
why is that?
Intel For The Win!!!
sharkattack99 is offline
post #23 of 51 Old 10-18-2011, 10:46 PM
kremtok's Avatar
Quoted: 0 Post(s)
Liked: 370
why is that?
In addition to the SLI / Crossfire issues that were mentioned earlier, the cost benefit just doesn't work out to get a stronger single card. It's nearly double the cost for not even 20% performance increase.
kremtok is offline
post #24 of 51 Old 10-18-2011, 10:47 PM
Sumatra's Avatar
Quoted: 0 Post(s)
Liked: 7
If you're gonna dish out the $ for SLI or CF get the fastest single GPU now, then crossfire or SLI later. I like Single GPU setups personally. Just seems to be less issues.
You can reach for the sky and endure its limitations. Or you can reach for the stars and enjoy it's eternity... Yeah... I made that up.
Sumatra is offline
post #25 of 51 Old 10-18-2011, 10:49 PM
Sumatra's Avatar
Quoted: 0 Post(s)
Liked: 7
GTX 580 price to performance is trash. Go with a GTX 570 or AMD 6970.
Sumatra is offline
post #26 of 51 Old 10-18-2011, 10:50 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 0
so what about say 2 of these http://www.newegg.com/Product/Produc...82E16814130620
by the way what is amds equivalent?
post #27 of 51 Old 10-18-2011, 10:50 PM
Classic Otaku
Quoted: 0 Post(s)
Liked: 408
Single GPU is always better than SLI/Crossfire.
* Less power consumption
* Less heat
* Less noise
* More expansion slots available (each GPU takes away 2 slots)
* No micro stuttering
People SLI/Crossfire because they want to achieve higher performance with less spending.
trumpet-205 is offline
post #28 of 51 Old 10-18-2011, 10:51 PM
Sumatra's Avatar
Quoted: 0 Post(s)
Liked: 7
why is that?
The only thing higher than the 570 or 6970 in single gpu config is the 580. And the price tag doesn't do justice. When you can get similar performance with an OC 570 for $150 less.
Sumatra is offline
post #29 of 51 Old 10-18-2011, 10:55 PM
Classic Otaku
Quoted: 0 Post(s)
Liked: 408
To be honest the best performance/price ratio for GPU is still GTX 560 Ti. Even GTX 570 has worse performance/price ratio.
post #30 of 51 Old 10-18-2011, 10:56 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 0
oh ok just deciding which one is the hard part.
