Graphics issue problem need help - Overclock.net
post #1 of 5 Old 03-07-2012, 04:08 AM - Thread Starter
Programmer
thecoredude98's Avatar
Quoted: 0 Post(s)
Liked: 3
I have this graphics issue and need help
Long story short... The screen occasionally shakes and turns blue and red and goes all 16bit on me....
The monitor is a FlatronL1740B and the graphics card is a NVIDIA GT210 with latest driver
I am forced to restart the PC when it happens
Any help is appreciated.
thecoredude98 is offline
post #2 of 5 Old 03-07-2012, 08:32 AM
axipher's Avatar
Quoted: 2 Post(s)
Liked: 268
Could be a possible faulty cable, or bad connection on either side. If I'm not mistaken that monitor only has a VGA connector. How do you have it connected to your GPU?
If direct by VGA, check both connections are secure and screwed in, or try another cable. If you're using a DVI-VGA dongle, it could be the issue as well.
thecoredude98 likes this.
Spoiler!
5 Million+ Folding at Home points  Chimp Challenge 2 x Participant  Foldathon Folder - 2012 Participant  BOINC Pentathlon Participant   Foldathon Participant 2015  Forum Folding War 2017
axipher is online now
post #3 of 5 Old 03-07-2012, 02:04 PM - Thread Starter
Programmer
Quoted: 0 Post(s)
Liked: 3
the VGA cable seems file but i don't think its the screen because when i reset the pc everything goes to normal.
post #4 of 5 Old 03-07-2012, 11:33 PM - Thread Starter
Programmer
Quoted: 0 Post(s)
Liked: 3
fixed it the card came lose in the PCI-E bridge on one side and when the vga cable moved it would move the gpu i screwed the gpu in haven't had the problem since
post #5 of 5 Old 03-08-2012, 06:55 AM
axipher's Avatar
Quoted: 2 Post(s)
Liked: 268
Great to hear you fixed it, I forgot about the PICe slot, always overlooking the simple things, that's me rolleyes.gif
Spoiler!
