***? Cutting out? - Page 2 - Overclock.net
post #11 of 16 Old 03-24-2006, 04:17 PM
4.0ghz
timmay7's Avatar
Quoted: 0 Post(s)
Liked: 60
Originally Posted by ElmStreet213
Yeah when your booting up tap F8 a few times that should bring up a menu so you can go into safemode.
its different from mobo to mobo tho. In the startup thing there should be "press <bios key> to enter bios and <bootup key> to enter bootup section". Check if theres any safe mode stuff there.
timmay7 is offline
post #12 of 16 Old 03-24-2006, 04:17 PM - Thread Starter
333mhz
F.Inferno's Avatar
Quoted: 0 Post(s)
Liked: 0
Ok, I have a 450Watt Modular OCZ Powersupply, Which I just bought like....TODAY.
F.Inferno is offline
post #13 of 16 Old 03-24-2006, 04:22 PM
4.0ghz
timmay7's Avatar
Quoted: 0 Post(s)
Liked: 60
if its AGP then there should be a 4-pin molex connecter thing.. make sure its properly in, or try it with another molex plug. If its a PCIe card then try with another PCIe power connecter.
OCZ Modstreams are well reputated in these forums, maybe yours have failed you. Doubt it tho because everything else works properly, doesnt it?
EDIT: Since that thing is modular try connecting your x800gt via other ports on the psu, and with a diff cable.
timmay7 is offline
post #14 of 16 Old 03-24-2006, 04:22 PM
Forum Manager
Quoted: 4 Post(s)
Liked: 1329
Well the power rating is fine but it could be dodgy but unlikely
Welcome to Overclock
ENTERPRISE is online now
post #15 of 16 Old 03-24-2006, 04:29 PM - Thread Starter
333mhz
F.Inferno's Avatar
Quoted: 0 Post(s)
Liked: 0
Ok, all I know is there is no place to put any sort of power supply on the GFX card.
And there is only one slot for the GFX card on the Motherboard....
post #16 of 16 Old 03-24-2006, 04:29 PM - Thread Starter
333mhz
F.Inferno's Avatar
Quoted: 0 Post(s)
Liked: 0
And yes everything else works absolutely fine.
You can even hear windows load up in the background.
