Best card to get for my system? - Overclock.net
post #1 of 22 Old 12-31-2010, 04:39 PM - Thread Starter
Commodore 64
smitjuH's Avatar
Quoted: 0 Post(s)
Liked: 0
Hey guys.
And ill blast in the new year with a question.
Last time i posted here i had bought a 5770, but that wasnt such a succes.
The card acted utter crappy on my system.
I RMA'd it for a Club3D 9800GT green edition 1024mb on their advice (bad choice tbh cuz it acts even worse)
So now ive put back in my old GTS250 which is a bit messed up.
(driver version atm 260.99)
But this card also doesnt achieve what i want.
I play alot of cod.. 4,5 and black ops.
And i need a card that gives me a stable 250 on cod4,125 on cod5 and 91 stable on black ops.
The store i buy my cards from says i cant go higher then a GTS250 due to my OS.. i have XP pro sp3, which supports dx9.
5770 for 1 supports dx11 and so on.
They said thats the reason the card didnt preform and a GTX460 or w/e would have the same effect.
I myself was thinking GTX260 or 4870 IceQ 4 turbo.
But i need some advice from the pro's.
What is the best card for me to buy???
my specs:
-E8400 @ stock 3.0Ghz
-2048 RAM Corsair
-750W PSU
-Asus P5QL-E mobo
I was thinking of OC'ing my 250 but i dont think it will make much difference.
(speeds atm: 740 core/1836 shader/1100 memory)
smitjuH is offline
post #2 of 22 Old 12-31-2010, 04:43 PM
Security Sleuth
Waffleboy's Avatar
Quoted: 0 Post(s)
Liked: 80
A gtx 260 would be fine for what you want to do. I have yet to find a game that I can't run on 1920x1080 resolution with moderately high settings. That said, it is getting to be a pretty old card, I know I will be upgrading in a year or so (at the outside).
"Do not trust Bunny-Cat!" - SF Debris
Waffleboy is offline
post #3 of 22 Old 12-31-2010, 04:49 PM - Thread Starter
Commodore 64
smitjuH's Avatar
Quoted: 0 Post(s)
Liked: 0
I run all my games on 800x600 or 1024x768
Most settings on low or w/e but i cant seem to hold a stable fps.
So a GTX260 would work on my OS?
How about the 4870?
The compagny i buy cards from say that the 4870 iceQ is dx10/11
smitjuH is offline
post #4 of 22 Old 12-31-2010, 05:00 PM
1.7ghz
xxmintixx's Avatar
Quoted: 0 Post(s)
Liked: 11
any card will work on your os... the only reason a video card wouldn't would be its to old to have a driver for the os.
build cost $400
c2d - free (: thankyou cuz
xxmintixx is offline
post #5 of 22 Old 12-31-2010, 05:02 PM - Thread Starter
Commodore 64
smitjuH's Avatar
Quoted: 0 Post(s)
Liked: 0
the 5770 wouldnt even hold a stable 250 fps in cod4, not even oc'd :S
Due to it not supporting dx9 (according to the store i bought it)
smitjuH is offline
post #6 of 22 Old 12-31-2010, 05:04 PM
2.4ghz
LiquidKaos's Avatar
Quoted: 0 Post(s)
Liked: 31
250fps? Isn't that slightly useless? What was the minimum fps?
LiquidKaos is offline
post #7 of 22 Old 12-31-2010, 05:05 PM
1.7ghz
xxmintixx's Avatar
Quoted: 0 Post(s)
Liked: 11
it does support dx9. or well as far as i know (i dont know allot about the 5XXX ati cards) why do you need 250fps? you wont notice the difference between 60fps and 250fps. 60 fps is a good fps. by stable you mean you dont want it to go under 250?
edit: hope i helped gota go do something with the car.. good luck with your comp
build cost $400
post #8 of 22 Old 12-31-2010, 05:08 PM
4.0 GHz
dihartnell's Avatar
Quoted: 0 Post(s)
Liked: 153
250 fps ??? did you mean 25?
I would stick with your 5770 and make a couple of changes to your system instead.
Get win 7 64 bit.
upgrade to 4GB RAM.
Get CM Hyper 212+ Cooler and overclock your CPU to 4GHz.
IMO its your system that is holding you back not the GPU.
dihartnell is offline
post #9 of 22 Old 12-31-2010, 05:09 PM - Thread Starter
Commodore 64
smitjuH's Avatar
Quoted: 0 Post(s)
Liked: 0
250 fps is essential in cod4 for a better hitreg and slightly faster shooting.
Specially when you play competative promod etc.
And with stable i mean it flicking between about 242/250 fps. but not dropping significantly to like 170/180 or w/e
smitjuH is offline
post #10 of 22 Old 12-31-2010, 05:12 PM - Thread Starter
Commodore 64
smitjuH's Avatar
Quoted: 0 Post(s)
Liked: 0
Get win 7 64 bit.
upgrade to 4GB RAM.
First of.. i dont have the cash to upgrade anything of that caliber
I allready rma'd the 5770 for that crappy 9800GT green thing
And im not even considering overclocking my cpu cuz i havent the slightest idea how to and i dont want to destroy my mobo/cpu, plus im not that technical to oc my cpu.
smitjuH is offline
